AutoCAD Civil 3D General
Active Member
Message 1 of 7 (491 Views)
Cogo point default label and layer settings
491 Views, 6 Replies
12-11-2012 10:31 AM
I am using Description Keys for all my points that I bring in from surveying in the field.  Any point that does not have a specific descriptor key ends up on a specific layer with a specific style that I cannot figure where to set.  I have gone through my point default settings as stated in other postings but all seem to be set correctly mostly to <none>.  I have gone through my Point Group settings without finding the culprit either.  I can easily change the settings as I only have a few points that do this but I want to find the issue.  Any help is greatly appreciated.
sboon
Message 2 of 7 (484 Views)
Re: Cogo point default label and layer settings
12-11-2012 11:09 AM in reply to: mahoneym
Typically I set it in the Create Points dialog within my template, and then forget about it after that.
tcorey
Message 3 of 7 (483 Views)
12-11-2012 11:10 AM in reply to: mahoneym
Settings tab of Toolspace, Point, Commands, right click Create Points, Edit command settings...
Find Default Layer to set the layer for all points that aren't controlled by DescKeys.
Expand Default Styles to control the styles of those points. If it is set to None, then these points will take on characteristics of the Point Group. If set here to something other than None, but you want the point group to control the display, in the Point Group Properties, go to Override tab and click overrides for Style and Label Style.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Active Member
Message 4 of 7 (476 Views)
12-11-2012 11:20 AM in reply to: sboon
Thank you both for the quick replies.  My settings are set in those commands as Default Layer <use current> and under Default Styles to the style I wish.
But the points still come in on another layer C-PNTS-TEXT (not my choice) and the style is not what I set.
sboon
Message 5 of 7 (472 Views)
12-11-2012 11:26 AM in reply to: mahoneym
If you look at the Command Settings dialog that Tim mentioned, is there anything in the Child Override column?
If you select one of these points and look at the Properties dialog you should be able to find out which point group it's part of.  Does that point group have any layer or style overrides in it?
tcorey
Message 6 of 7 (466 Views)
12-11-2012 11:32 AM in reply to: mahoneym
Double check your description keys to be sure you don't have a code that is picking up points you don't intend.
Post your drawing and ascii point file.
Tim Corey, Owner
Redding, CA
Active Member
Message 7 of 7 (466 Views)
12-11-2012 11:33 AM in reply to: sboon
No child overrides but it worked when I changed the selection of <current> layer to a specific layer and began a new drawing and reimported my points.  The styles followed the defaults I set too.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
