Civil 3D Forum
Closed polyline (CAD) to polygon FEATURE (GIS)
3 REPLIES 3
bcsurvey
1176 Views, 3 Replies
I have been forced to enter the realm of GIS and it's not pretty.
This may be more a GIS question, but their forums seem to be focused on coding.
I know how to export a closed polyline out of C3D as a .shp then bring it into GIS as a new layer.  But what is the procedure for moving this single polygon layer into an existing polygon layer as a feature (one of many existing polygons in existing layer)?
Civil 3D 2019 (6.1)
Windows 10 Pro (21H2)
(i7-11850H @ 2.50 GHz)
32GB RAM
NVIDIA RTX A2000
3 REPLIES 3
antoniovinci
in reply to: bcsurvey
You can simply _MAPIMPORT the two shapes in an empty .DWG then _MAPEXPORT all to a unique polygon shapefile.
Murph_Map
There's a merge shp tool in ESRI if that's the GIS software you're using.
Murph
Supporting the troops daily.
bcsurvey
in reply to: Murph_Map
Thanks for the replies.  I did go with the merge tool (Under Geoprocessing pull-down menu) in ArcCatalog.  I had to redo it when I realized that I wanted the "new" features to be placed at the bottom of the attribute table, not at the top as I had done originally.  Redoing it with the input data stacked to reflect the order in the destination dataset was an easy fix.
You both provided valuable information for me, so you both get a green check!
Thanks again
Civil 3D 2019 (6.1)
32GB RAM
NVIDIA RTX A2000
Rail Community
