Civil 3D Forum
Civl 3D Polylines
23 REPLIES 23
Message 1 of 24
lex123456
1348 Views, 23 Replies
Civl 3D Polylines
Why does Civil 3D not have options to edit 3D polylines? Specifically linetype scales. I read what was posted previously and a tip someone gave was explode it to 2D, do a pedit, print and then exit drawing without saving. This is not acceptable. This is a survey file provided to me as a base for design and the 3D polylines are tops of banks. Carlson Survcadd allows you to edit 3D polylines. Why doesn't Civil 3D?
23 REPLIES 23
Message 21 of 24
jmayo-EE
in reply to: lex123456
And if you want to use the profile layout tools, click the command to start the tangents and type 'pse into the command line (or look for the toolbar buttons) to activate the Profile Station Elevation transparent command.
John Mayo
Message 22 of 24
BrianHailey
in reply to: jmayo-EE
Or you could use the button on the layout tools toolbar, "Insert PVI's Tabular". This will allow you specify different curve lengths as you input the pvis.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 23 of 24
jmayo-EE
in reply to: BrianHailey
Good stuff!
The OP got max use from this thread. 🙂
John Mayo
Message 24 of 24
lex123456
Thanks y'all! Good stuff here.
Rail Community
