Civil 3D Forum
Civil3d has potential, but too high level UI
43 REPLIES 43
Message 1 of 44
762 Views, 43 Replies
After playing with Civil3D a bit and attending a presentation by Autodesk
showing the new software, a couple of things are evident about the new
release. The software will be incredibly powerful on the front end -
conceptual planning can be done with a high degree of efficiency, and makes
it easy to give layouts to our clients. Threre has been a big discussion
about the lifecycle of data from Autodesk, and I can't agree more, that the
longer the data can be maintained and used without reconstructing or
recaluculating it, the more valuable it is. The unfortunate problem with
Civil3d as it seems to be developing is that the UI (user interface) is very
high level - it tries to make it simple enough for a drafter with little
experience able to do a lot of design by not digging into the details, which
would require a lot more parametric design, such as CAICE and the sort.
However, when projects near construction, there are always numerous details
that exist regardless, and it means that the entire model must be exploded
and torn apart so that the details can be added since the software doesn't
provide the flexibility.
I understand there is a tradeoff of UI flexibility and how easy it appears
the program is to use, but Autodesk needs to consider the change in the
office environment as Engineers in the next generation are moving to doing
design on paper to design on computer. Most of my peers are drafting 80
percent of their work. If a lower level UI means carrying a model to
construction (or production) without losing the data and passing the full
model to the contractor as part of the bid package, then it's well worth
doubling the price of the current software package.
Maybe Civil3d should consider breaking up into modules for different aspects
of design, such as road design, utility design, site design, and the sort
that could be purchased separately to recoup more costs and provide more
comprehensive UI's for different projects. It just seems most of my peers,
the engineers about to hit the thirties that have grown with CAD are looking
for this project. We're there, but there's nobody in the market to supply
the need.
43 REPLIES 43
Message 21 of 44
I could not disagree more. Are you saying that LDD is easier to use than
Civil3D? Hardly. You really need to try using it. The menus are well
organized and SHORT. Most of the functionality is available by right
clicking on the object you want to modify. You don't have to be a guru with
Civil3D the way you must be with LDD. Many concepts have changed, but if
you're saying that most people don't know how to use LDD, then they
shouldn't have to re-learn much.
Your comment are a bit puzzling. It sounds like either the demo you saw was
not very good, or you were sleeping through it. The problems you mentioned
with tweaking your vertical profile & having to redo a bunch of steps are
the exact problem that Civil 3D is designed to avoid. Your alignment,
profile, & dtm are all tied together. Changing one object causes the others
to be automatically updated. In addition, labels are also tied to the
object and are plan readable, regardless of the view's UCS and update
automatically when the object changes. These are the EXACT things that LDD
users have been asking for.
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
"Dave Lewis" wrote in message
news:cor9svobe1kb5hb37ghlukj0jeaiu7nq7v@4ax.com...
> I know I'm a little late to this thread but here is my nose errr I mean
opinion
> After seeing the UI (not using) I would agree that it has gotten alot more
complicated
> compared to LDD. In the last 4 companies I have worked for very very few
people really
> had a good handle on LDD. Most just don't know how to use it. Civil
engineers don't seem
> to make strong computer users in my experience. Civil engineering is not
rocket science and
> thus does not need a rocket science's program. Most people I know want a
simpler experience
> using LDD, not more complicated.
> I really wish Autodesk would do more to ask its LDD users before hand what
they want. Maybe
> I am in the minority, but I want a product that will help me design on a
computer. I want at the least
> a program that does away with the repetitiveness off LDD. For example.
If I want earthworks on
> a new road alignment, I design a hor/ver alignment, do templates, create a
surface and then do
> my earthworks calcs. Now if I tweak my vertical profile, I have to
basically redo every step again
> to get my new earthworks numbers. That is ridiculous. Like the
mechanical programs, I should be
> able to tweak one area and everything else automatically adjusts, thus
killing the receptiveness.
> That would be such a huge time saver and would really be helpful.
> Sure drafting aids would be nice, but I think most companies have already
developed their own
> methods / tools to draft plans according to their needs. This isn't such
a big issue to me nowadays.
> I don't think you could really program an automatically drafting plan set
making product.
> One thing I do get constantly asked is how can I do this or why doesn't
LDD work like Terra Model
> or Microstation or whatever program. Really I wish Autodesk would
recognize competitors like them
> and evaluates some of the great ideas that those programs can do.
> After these things are addressed then the UI can be tweaked, but just
don't make it a drill down hell
> interface, no one likes hidden options that you have to hunt for to find.
> Dave Lewis
> CAD Manager
> Just say no to HTML Posts!
Message 22 of 44
The jury is still out on C3D cuz there is no shipping product yet. From what I have
seen there is a totally new interface to get used to. That could be good or bad, not
sure yet. But I do hate having to drill down a bunch of cryptic icons/options to find
stuff. Then there is the problem of going 2 or 3 different places to accomplish the
same thing. I don't really like that, it seems like the software designer could not make
up their mind. We will see about the complexity with the final product. But so far the
options look a little complex.
As far as LDD goes, yes I agree its a pain and hopefully C3D fixes its short commings.
Yes I know about the auto updated featurs of C3D. My point was that it should have
been in LDD years ago.
I have gotten LDD dumbed down to a few simple toolbars and it works well for what
civil drafters need. But stray from that and you have to be a guru to use ldd 🙂
"Jon Rizzo"
Dave Lewis
CAD Manager
Message 23 of 44
what I have
or bad, not
Yes, and I suppose you hate long menus, too. I have some bad news for you:
in windows programs, you have to choose: icons or menus. If you can come up
with a 3rd option, you will make a lot of money. A new interface is not a
bad thing - LDD's UI is extremely clunky. If learning something new is
what's bothering you, then I would recommend finding a career that doesn't
involve computers.
accomplish the
could not make
But so far the
Is it so difficult to just ignore the 2 or 3 different ways, pick one, and
run with it? If there was only one way to do certain things, you would
probably be complaining about the way that they chose. Everything that you
hate about one way, somebody else may like. There is no way that 1 method
for everything will make everyone happy. Look at AutoCAD - there are 10
ways to do everything, and that's one of the things that people like about
it. If you don't want to use the other ways, DON'T! Sure, there is a
certain amount of complexity to the program, but I would challenge you to
come up with something better that also satisfies the diverse needs of
Autodesk's customer base. What you need out of the program is not
necessarily the same thing that I need from the program, even though we may
both work for civil engineering consultants.
short commings.
should have
Why do you think these features should be in LDD, if you agree that LDD is a
pain? I think a ground up rewrite was the best choice. Shoe-horning
features into a 20 year old product is what got us to where LDD is today -
it is by no means an answer for tomorrow! Look at Windows, for example.
For a long time, Windows was just an extension of DOS. It was not nearly as
useful or powerful (or STABLE!) until they took the best features and
integrated them into an operating system that was written independently of
the DOS based program. All of the features of DOS are still there (often in
a different form), but Windows is no longer an extension of DOS. Try to
look at Civil 3D with the same open mind.
for what
ldd 🙂
The era of the "civil drafter" is almost over. Once Civil 3D is
feature-complete (and stable!), there will be little or no need for
non-engineers to use it. Drafters/designers can use AutoCAD, and engineers
will use Civil3D. The mindless, repetative tasks simply won't exist (or at
least they will be dramatically reduced). The drafting is a "byproduct" of
the design work being accomplished. It's an afterthought, since it happens
automatically as you work. The Civil 3D guru will be the one who knows how
to configure the styles properly to have the desired information shown on
the plans. Most users will not have to be "guru"s to use it, they will just
choose a predefined style that a guru has set up for them.
As I said, it would be better to reserve judgement until you actually use
it. There are plenty of things wrong with the current state of Civil 3D,
but you don't seem to have touched on any of them. Complaints that
"such-and-such isn't available in LDD" will fall on deaf ears, so if you
wish to remain sane, it would be best to just let it go.
Jon Rizzo
Message 24 of 44
"Jon Rizzo"
|>involve computers.
opening dialog after dialog or drill down is a bad interface, just because microsoft
does it, does not mean its a good way to go. Interfaces should be intutative, not
oh I remember this setting in this dialog, now where is that dialog?
Yup and I always seem to explain the same thing 5 different ways to people
then they look at me and say what's the best way?
My point was that LDD has been the same ol thing for what 10 years now.
A change should have happened a long time ago.
Ya I've heard that my entire career. You will always need lower paid tech's
to clean up and do busy work because the engineers are too busy. Also
typically in my experience the sr level drafters know the programs better
then the engineers. It seems that engineers want to engineer and drafters
want to run software.
This whole thread was about the UI, not stability issues or actual problems
with the beta software. From what I have seen options / settings are
very well hidden thus making the software appear to be simpler. All I know
is I'm gona have to spend a bunch of time developing standardized settings
that I hope I can roll out to all the installations, cuz the number of settings /
options are dizzing.
Dave Lewis
CAD Manager
Message 25 of 44
microsoft
intutative, not
Actually, I find it very intuitive. You may not, but then again, you
haven't used it.
So decide which way you think is the best way, and only explain that one.
Agreed, but it is here now. Why waste energy complaining about the past?
It is time to move on.
tech's
Yes, but the amount of busy work will be a very small fraction of what it is
now. Personally, I won't want drafters touching Civil3D, as they would be
too prone to screw something up that they aren't supposed to. There simply
isn't a need for a drafter to use Civil 3D. Any cleanup that is necessary
can be done in AutoCAD without the risk of them modifying the design
information.
settings /
As you should with ANY piece of design or CAD software. Again, you really
should work with the software before you speculate. These settings can be
shared using regular old autocad template files.
Rather than lots of options, I suppose you expect them to provide software
configured exactly the way YOU want it, and ignore what everybody else
needs? Keep in mind that you are not their only customer. If there are a
lot of options, then it is for a reason. Personally, I prefer the
flexibility because it allows us to prepare drawings the way WE want them to
look.
How do you think it should look? How would you recommend fitting all of
those options into a program in a way that would make things easier to find
than they are now?
Jon Rizzo
Message 26 of 44
its all speculation at this point because there is no shipping product. Whether you
have used it or not you do not know what the final shipping product will be like.
I can handle the software however it comes out, does not make a huge difference
either way. What my overall general comment about software design is to keep
it simple, make it easy to use, intutative user interface, so that the user does not
have to RTFM. That makes my job as tech support much easier. The better or
easier the software is to use, the easier my job is. The less I have to demonstrate,
document, explain.
Based on past experiences with autodesk software this has not been the case.
The software increasing gets more complicated, not easier to use. I still have
users who don't understand about right clicking. They are engineers with years
of experience. They know what they want the software to do, but still come back
to me asking stupid or lets say tiresome questions over and over again. That
I like to avoid.
"Jon Rizzo"
|>look.
|>than they are now?
Dave Lewis
CAD Manager
Message 27 of 44
news:o61ftvgehd6p4n0k5721cvl2542o9ld0dr@4ax.com...
> I still have
years
back
That
>I like to avoid.
BWWAAHAHA! Dave, on the outside chance that you are not kidding, I just
thought I'd tell you that the problem is not AutoDesk. The problem is you
have somehow become employed by a bunch of total Bafoons.
If your engineers can't understand simple concepts, and remember them how
could AutoDesk make this lack of brains any better?
I think what you want is a piece of software that works like the Auto Parts
computer at Wal-Mart. Just click a couple of times and you have the part
number for the tail light on a 73 Cutlass. This is design, and it is
complicated. If your engineers can't figure it out, get new engineers cause
the rest of the world isn't going to "dumb down" for your benefit. Does
anyone hand feed your engineers their lunch?
Thanks for the laugh! That was a good one!
Tim
Message 28 of 44
hey I just had to explain how to use etransmit to a guy who needed to send a ctb
file to another consultant. my guy never heard of a ctb file before. He knew what
a pcp file was. You should have seen the look on his face when I showed him how
it was so much better then pack-n-go. I got to deal with this kind of stuff all my career
and this is the 4th company Ive been at.
"Tim S."
Dave Lewis
CAD Manager
Message 29 of 44
You have got to get out of there bud. Working with idiots can poison an
otherwise bright mind. You have already been around these dips long enough
to think it is AutoDesk's fault. Try this: the next time one of them asks a
really dumb question, knock on their head and say, "Ummm hello? Earth
calling Engineer Goober. Just to give you an example, I have two people
with nothing more than a high school education that can design anything.
Complete with Hydro, slope stability, etc. They do everything totally 3d.
Any time the new version comes out, they are experts within a month. When
you do it this way, you get intelligent design and the really flaked out
engineers like what you are talking about can stay in their office and do
frost heave calculations for their Miami job.
For our engineers who lose sleep over whether epoxy will be applied to a
pipe connection correctly, and try to fix the problem with a page of
details, we just put them out in the field for a couple of years. When they
finally get in out of the cold, they don't squeak nearly as much when they
walk. They also tend to stop trying to show Anchor Bolt Details complete
with the angle between the threads also.
Tim
news:td7itv4maibfhpu54vcqahv04u8n55jmkt@4ax.com...
a ctb
knew what
him how
stuff all my career
Message 30 of 44
You guys are all twisted because an engineer didn't know what a *.ctb file
was? Sheesh, us engineers have to leave some crumbs on the table for you
guys to exist.
It's this kind of "chip on the shoulder" attitude from non-revenue
generating support people that can really bring down the efficiency and
profitability of an office. Unfortunately upper management all too often
doesn't see or understand the technical exchanges between engineers and
computer support staff, or they would take steps to mitigate the problem
before it results in the unsustainable loss of revenue, then office jobs.
We had a lead support person in the company I use to work for who
stonewalled the engineers as you talk about doing. We went from a Land
Development staff of 35+ to 4 over 4 years. Everyone complained about him,
but he was manged under corporate and was for some reason "untouchable" by
the local branch office. His attitude hampered the development of a lot of
the staff. He ended up losing his job though eventually also due to the
office downsizing.
Fred
Message 31 of 44
I believe it was only Dave that was twisted.
What really perpetuates the problem is the general attitude that an engineer
should not need anything more than "how to turn it on" computer skills to
drive complex design software. It is not reasonable to expect every
engineer to be a computer expert, but yes, repeatedly giving the same answer
to the same question to the same person gets a little tiring after a while.
My problem is with those who refuse to try & instead insist that it's
somehow my fault when they don't know how to fix a problem that they're
having.
Jon Rizzo
"Fred Ernst" wrote in message
news:1FCE4F296F1C252B5CD6EE9B5EF8E693@in.WebX.maYIadrTaRb...
> guys to exist.
> office downsizing.
> Fred
Message 32 of 44
Fred, you are one of the guys that understands the whole thing top to
bottom. I like working with engineers with your kind of hands on
intuitiveness. The ones that makes me batty are the guys that want to list
property line coordinate corners out to 16 decimal places because that is
what the computer generated.
No doubt that when you get an engineer (like you) life gets easier quick.
But if we didn't have the Goobers in the office there would be no one to
laugh at.
Tim
> guys to exist.
> office downsizing.
> Fred
Message 33 of 44
I still remember my college days, when a student presented a cost estimate
for a $30 million project that she had worked on all semester. Her estimate
was shown to the nearest penny.
Jon Rizzo
"Tim S." wrote in message
news:1975BCCB038A9EEFF541BE24C712ADA5@in.WebX.maYIadrTaRb...
> laugh at.
> Tim
file
> > guys to exist.
jobs.
him,
by
of
> > office downsizing.
> > Fred
Message 34 of 44
Don't laugh too hard...I did one in college where I forgot to divide by 27
to get cubic yards instead of feet when dealing with pipe excavation. Could
have build the sewers out of gold I was so far off. :-$
The UI in C3D is for an engineer to use. Not a dumb engineer, but a properly
trained, relatively computer literate engineer. For those that don't train
their engineers to use the software, or consider them too dumb to use it,
I'm happy. I'm happy to steal your clients when they realize how much money
you're wasting doing it old school.
C3D is for engineers, accept that, and plan deployment/training accordingly.
James Wedding, P.E.
IT Manager
Jones & Boyd, Inc.
Dallas, TX
XP/1 on P4-1.6/512
LDT2004+C3D
Message 35 of 44
Bonk. Don't give yourself too much credit. This software is for people who
use it every day. Civil Engineering is not rocket science, it is simply
shaping dirt and conrete. I'll take a tech with twenty years experience over
a young engineer any day.
When you get a Fred Ernst who is not only an engineer but also applies
himself to learning the software, then you really have something.
One thing for sure, this software doesn't require a P.E. to be used
properly. It requires a dedicated user with advanced knowledge of
construction techniques.
Tim
"James Wedding" wrote in message
news:E96151AB1336F20530C17A387DDB68A4@in.WebX.maYIadrTaRb...
Could
properly
money
accordingly.
> James Wedding, P.E.
> IT Manager
> Jones & Boyd, Inc.
> Dallas, TX
> XP/1 on P4-1.6/512
> LDT2004+C3D
Message 36 of 44
Agreed. I'm just tired of the complaints from people that (1) have never
actually used the software, even in preview state, (2) want it written to
the lowest common denominator.
CE isn't rocket science, but it's not simple additon either. I've said over
the years, that all things being equal, I'd rather teach an engineer to use
cad than teach a cad user to engineer. Here's hoping that we both get what
we need from the software when it ships in a final state.
James Wedding, P.E.
IT Manager
Jones & Boyd, Inc.
Dallas, TX
XP/1 on P4-1.6/512
LDT2004+C3D
Message 37 of 44
100% agreement here.
news:2FDF4D2B8F1E11863EC4843A31F5F5A9@in.WebX.maYIadrTaRb...
over
use
> James Wedding, P.E.
> IT Manager
> Jones & Boyd, Inc.
> Dallas, TX
> XP/1 on P4-1.6/512
> LDT2004+C3D
Message 38 of 44
No, you wouldn't be working with engineers like me because we don't need
your services. Seems like you're there primarily for the Goobers. I guess in
regard to your chosen field, you should be glad there are Goobers to serve.
Fred
Message 39 of 44
properly
money
Hi James and all,
When you say "is for an engineer to use", does that mean it is beyond the
designer who isn't formally educated as an engineer? Since you use the term
"trained" as opposed to "educated", I assume that as a designer, I can
operate the software with my experience and training. The reason I ask is
that I'm currently pursuing purchasing LDT4 would like to test this C3D
gizmo. I do much of the design at my company before the PE takes over. If it
is above my head, then I will have to continue in the old school (LDT).
Rick
Message 40 of 44
YES
Jon Rizzo
over
use
> James Wedding, P.E.
> IT Manager
> Jones & Boyd, Inc.
> Dallas, TX
> XP/1 on P4-1.6/512
> LDT2004+C3D
Rail Community
