The Land Desktop project structure allowed data to be saved externally to create a single authorative original of each object, and yet the drawing could still interact with it, in a Read Only or Read&Write fashion. This kept drawing sizes to a minimum, effectively archived (backed-up) data and allowed data to be shared. It seems difficult to achieve the same thing with C3D.
So...
1. How do we best manage large projects with lots of object data (points, surfaces, alignments, profiles, assemblies and corridors)?
For a start you don't want all of the objects visible at once, but you do need new objects to be able to interact with everything else. So how do you have them all on tap without having a cluttered drawing and significantly reduced computer performance.
For example you start with a NG surface and then integrate design info to create a FG surface. Once you've done that you can get rid of your NG surface - but no, it has to stay in the drawing because your FG surface is dependent on it. So you still need it in the drawing, but you don’t want to see it (and you don't want it compromising your performance).
2. What's the best way to secure (backup) data in case there's a crash?
You may complete a road corridor design and be entirely happy with it. You still need access to it so that your next design object can interact with it, but you want to lock it down so it's not compromised by a crash (or user error). So you can save it in another drawing, but you want to be able to identify that object as the original one, and still be able to interact with it.
3. What's the best way to share data between users? A typical project will have survey measurements, topo information, surfaces, design info and legal boundary data (etc) all being prepared and used by different people. So the data needs to be able to be shared between users.
I appreciate that I could archive data in LandXML format, but it doesn’t create an authoritative, definitive, original that I can interact with.
I know that C3D is a different way of working, but help me get my head around it. What's the best way to manage the data and the design process?
Any thoughts would be appreciated.
Michael
WinXP SP2
LandDesktop 2005 SP 1 & Civil3D 2005 SP 1
Michael
AEC Collection - Civil3D 2023 & Infraworks 2023
www.foxsurvey.co.nz
