Valued Contributor
raghulan
Message 1 of 4 (484 Views)
Civil3D COGO Point User Defined Property Unable to delete (Dependency)
484 Views, 3 Replies
06-05-2013 06:47 PM
 I created UDP Classification and then created User defined property, for some reason one of the properties under a classification has a dependency and I am unable to delete it.
How do I delete the UPD and the classification.
There is a dependency mark on top of the name "Handle"
Under what circumstances we get that and what all the dependencies.
How do I delete the UDP in this case.
Thanks.
Raghulan Gowthaman Cert IV TAA, B.E,.
Senior Technical Consultant | Developer - R&D
A2K Technologies Sydney
Web : www.a2ktechnologies.com.au
www.civil3dforum.com | www.e4forums.com
www.zcodia.com.au
www.raghulangowthaman.com
Jeff_M
Message 2 of 4 (478 Views)
Re: Civil3D COGO Point User Defined Property Unable to delete (Dependency)
06-05-2013 07:17 PM in reply to: raghulan
You have to delete the value assigned to any points in the PointGroup(s) you assigned the Classification to. Even after removing a Classification from a PG, it looks like the Point(s) that had values assigned retain those values...I guess in case you decide to re-assign the classification.
Valued Contributor
raghulan
Message 3 of 4 (474 Views)
06-05-2013 07:29 PM in reply to: Jeff_M
I even tried deleted all points (All Objects) from the drawings still it seems to be the issue.
Will look and try few other things and if I find something, will post..
Thanks for your help.
www.zcodia.com.au
KTitus
Message 4 of 4 (322 Views)
09-27-2013 09:45 AM in reply to: raghulan
You can also check any point file formats or other commands that may be referencing that property
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
