Civil 3D Forum
Civil3D COGO Point User Defined Property Unable to delete (Dependency)
3 REPLIES 3
1583 Views, 3 Replies
 I created UDP Classification and then created User defined property, for some reason one of the properties under a classification has a dependency and I am unable to delete it.
How do I delete the UPD and the classification.
There is a dependency mark on top of the name "Handle"
Under what circumstances we get that and what all the dependencies.
How do I delete the UDP in this case.
Thanks.
3 REPLIES 3
Jeff_M
You have to delete the value assigned to any points in the PointGroup(s) you assigned the Classification to. Even after removing a Classification from a PG, it looks like the Point(s) that had values assigned retain those values...I guess in case you decide to re-assign the classification.
in reply to: Jeff_M
I even tried deleted all points (All Objects) from the drawings still it seems to be the issue.
Will look and try few other things and if I find something, will post..
Thanks for your help.
You can also check any point file formats or other commands that may be referencing that property
Rail Community
