Valued Contributor
BrandenH
Message 1 of 10 (1,266 Views)
Civil3D 2012 - Error on Close
1266 Views, 9 Replies
05-24-2012 06:20 AM
I've recently switched to Civil 3D 2012, and after I close the program I get the attached error.  It's just a yellow triangle with an exclamation point... Anyone know what causes that and how to fix it?
rkmcswain
Message 2 of 10 (1,240 Views)
Re: Civil3D 2012 - Error on Close
05-24-2012 08:44 AM in reply to: BrandenH
Do you have (or have you ever had) any 2013 products installed? Including betas?
Valued Contributor
BrandenH
Message 3 of 10 (1,235 Views)
05-24-2012 08:50 AM in reply to: rkmcswain
No, I have LDD/Civil3d 2009, Civil 3d 2011, and Civil 3d 2012 installed.
Jeff_M
Message 4 of 10 (1,233 Views)
05-24-2012 08:53 AM in reply to: BrandenH
This is usually just a benign error message. There is a long thread regarding this from a few months ago, and the genreal consensus is that is more annoying than anything else. Sometimes a repair install will make it go away.
Valued Contributor
BrandenH
Message 5 of 10 (1,231 Views)
05-24-2012 08:56 AM in reply to: Jeff_M
I tried looking for a post on this, but couldn't find anything other than Fatal Errors, of which this appears to not be.
neilyj
Message 6 of 10 (1,227 Views)
05-24-2012 08:57 AM in reply to: BrandenH
I get this every time I close down 2012
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Jeff_M
Message 7 of 10 (1,223 Views)
05-24-2012 08:59 AM in reply to: BrandenH
rkmcswain
Message 8 of 10 (1,217 Views)
05-24-2012 09:06 AM in reply to: rkmcswain
I remember reading something that indicated that 2012 will do this after 2013 is installed. But obviously there is more to it than that. I used to get the "!" dialog, but now mine just beeps twice when shutting down (the "beep being whatever Windows sound plays when there is an error)
Valued Contributor
BrandenH
Message 9 of 10 (1,186 Views)
05-24-2012 12:31 PM in reply to: rkmcswain
So then, I'll just have to deal with it.  For some reason, we don't have an install disc to do a repair.
Active Contributor
jfengineering
Message 10 of 10 (1,175 Views)
05-24-2012 02:14 PM in reply to: BrandenH
Unfortunately all I can do is confirm that I'm getting the same error message with my new install of C3D 2013 64 bit.  I moved up from 2012 C3D, 32 bit.  Mostly annoying, but it would be nice to get rid of it.  I'll try the repair....
JF Engineering, PLLC
Civil3D, 2104
Windows 7 Pro, 64 Bit
ASUS SABERTOOTH Z87
Intel i7-4770K, 3.50 GHz
16 GB RAM
2x HP2311x Monitors
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
