Civil 3D Forum
Civil3D 2012 - Error on Close
9 REPLIES 9
Message 1 of 10
BrandenH
1735 Views, 9 Replies
I've recently switched to Civil 3D 2012, and after I close the program I get the attached error.  It's just a yellow triangle with an exclamation point... Anyone know what causes that and how to fix it?
9 REPLIES 9
Message 2 of 10
rkmcswain
in reply to: BrandenH
Do you have (or have you ever had) any 2013 products installed? Including betas?
Message 3 of 10
BrandenH
in reply to: rkmcswain
No, I have LDD/Civil3d 2009, Civil 3d 2011, and Civil 3d 2012 installed.
Message 4 of 10
Jeff_M
This is usually just a benign error message. There is a long thread regarding this from a few months ago, and the genreal consensus is that is more annoying than anything else. Sometimes a repair install will make it go away.
Message 5 of 10
BrandenH
in reply to: Jeff_M
I tried looking for a post on this, but couldn't find anything other than Fatal Errors, of which this appears to not be.
Message 6 of 10
neilyj666
I get this every time I close down 2012
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 7 of 10
Jeff_M
Message 8 of 10
rkmcswain
I remember reading something that indicated that 2012 will do this after 2013 is installed. But obviously there is more to it than that. I used to get the "!" dialog, but now mine just beeps twice when shutting down (the "beep being whatever Windows sound plays when there is an error)
Message 9 of 10
BrandenH
So then, I'll just have to deal with it.  For some reason, we don't have an install disc to do a repair.
Message 10 of 10
jfengineering
Unfortunately all I can do is confirm that I'm getting the same error message with my new install of C3D 2013 64 bit.  I moved up from 2012 C3D, 32 bit.  Mostly annoying, but it would be nice to get rid of it.  I'll try the repair....
JF Engineering, PLLC
Civil3D, Current/Win 10 Pro
MSI MPG X570/AMD Ryzen 5 3.6 GHz
EVGA GTX 1650, 4GB
1TB Samsung 970 M.2
16 GB DDR4 3200MHz RAM
2x ViewSonic VX2458 24in Monitors
Rail Community
