AutoCAD Civil 3D General
Member
sowhoong.tung
Message 1 of 7 (456 Views)
Accepted Solution
Civil View - Coordinate system.
456 Views, 6 Replies
01-20-2013 06:11 AM
I was trying to export 2 surfaces from Autodesk Civil 3D 2013 to Civil View in Autodesk 3ds Max Design.
However I found that the 2 surfaces are shifted away after importing them in Autodesk 3ds Max Design.
I have adopted Global Import Scene as recommended by Civil View but the result is still the same.
Any clue?
I suspect that I mess up with my 3ds max design settings accidentally.
*Expert Elite*
BrianHailey
Message 2 of 7 (433 Views)
Re: Civil View - Coordinate system.
01-20-2013 09:20 AM in reply to: sowhoong.tung
  • Does this happen on just your machine or other machines as well? If you only have the one machine with 3ds Max, you can post the file up here and someone will be able to test it for you I'm sure.
  • Have you seen this happen on different data sets?
  • Has either one of your surfaces been moved in Civil 3D? Check the edits of each surface for a "Transformed by" edit.
Hopefully this will help us get to the bottom of the issue.
Member
sowhoong.tung
Message 3 of 7 (406 Views)
01-21-2013 04:05 AM in reply to: BrianHailey
Thanks Brian.
Does this happen on just your machine or other machines as well? If you only have the one machine with 3ds Max, youcan post the file up here and someone will be able to test it for you I'm sure.
Sorry, I don't have second machine to test.
Due to the size of the file, i uploaded to dropbox.  Please get it from here
Yes. Same result on my other project as well.  However, if i'm not mistaken, I have imported drawing once without any issue(when 3ds Max was freshed install).  Until I have gone through few tutorials by autodesk, I only found this issue.  I wonder if i have mess up with the setting  in 3ds Max during the tutorial.
Has either one of your surfaces been moved in Civil 3D? Check the edits of each surface for a "Transformed by" edit. Hopefully this will help us get to the bottom of the issue.
No.
*Expert Elite*
BrianHailey
Message 4 of 7 (369 Views)
01-21-2013 09:59 AM in reply to: sowhoong.tung
Seems to be working just fine for me. I honestly don't know what would be causing the issue.
Member
sowhoong.tung
Message 5 of 7 (341 Views)
01-21-2013 05:07 PM in reply to: BrianHailey
Thank you Brian.
May I know have you adopted the Global Import Shift setting?  What is the coordinate showing in the 3ds Max plan?
*Expert Elite*
BrianHailey
Message 6 of 7 (332 Views)
01-21-2013 08:34 PM in reply to: sowhoong.tung
I did accept the shift. Unfortunately I don't have access to the data right now and I'll be going on vacation later this week so I probably won't be much more help. Perhaps someone else can help you out.
Member
sowhoong.tung
Message 7 of 7 (317 Views)
01-22-2013 05:36 AM in reply to: BrianHailey
Brian, really appreciate your help.
I manage to solve it by reinstalling the 3ds Max Design.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
