I am attempting to export a number of pipe networks to 3DS using Civil 3D's Civil View tools. I have the extension of 8/8/2013 installed, but neither my gravity networks nor my pressure networks are appearing in Civil View's export dialog (see below). Civil View does successfully export the surface.
Is another extension required to export pipe networks and pressure networks to 3DS? Any help would be appreciated.
Solved by Krite1. Go to Solution.
Are you using the extension command via the subscription extension manager within the Toolbox section of the Toolspace window. This will export the pipe networks seperately.
