Civil 3D Forum
Civil 3d contours from existing polylines
10 REPLIES 10
Message 1 of 11
MKH-VB
10036 Views, 10 Replies
trying to create a model from existing polylines (at elevation).  I have created a surface, went to definiltion, drawing objects, but there is no "polyline" option there.  I must be missing something.  How can I create a c3d model from existing polylines?  Thanks.
MKH
mkh
10 REPLIES 10
Message 2 of 11
awood
in reply to: MKH-VB
Instead of the Drawing Objects option use the Contours option under the surface definition.
HTH
AWood
Message 3 of 11
Adam_Farnsworth
in reply to: MKH-VB
And when adding the polylines as contours, play with the weeding and supplementing factors to make sure the surface is modeled as close to what you want as possible.
Windows 7 x 64
ATI Radeon HD 5700 Series
12 GB Ram
i7 920 @ 2.67 GHz
Civil 3D 2011, 2010, 2009 and occasionally 2008 still (unfortunantly)
Message 4 of 11
MKH-VB
in reply to: MKH-VB
thanks for the help guys. Just what I needed.
mkh
Message 5 of 11
jeremy.2012
in reply to: awood
I was able to make a surface but when I try to at elevation labels, no figures show up after I drag it across my polylines.  Does it make a difference that my plines (that are at elevation) aren't continuous contour lines around the entire drawing?
Message 6 of 11
BrianHailey
in reply to: jeremy.2012
When you are adding contours to a surface, make sure you toggle on all the minimize flat areas options. Here's why: http://civil3dplus.wordpress.com/2011/08/13/adding-contours-to-a-surface-youre-doing-it-wrong/
Jeremy: You don't label the polylines, you label the surface. You need to change the style of the surface to display contours and those you label.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 7 of 11
JamaL9722060
in reply to: awood
I’m encountering the same issue and couldn’t know how to build a contour surface from polylines with elevations
The contour option doesn’t build a contour surface from polylines!
Where might be my mistake?
Thank you
Best
Jamal
Jamal Numan
Message 8 of 11
Jeff_M
in reply to: JamaL9722060
Make sure you select all of the polylines at once to add as Contour data, make sure the Surface style is set to display the contours.
Message 9 of 11
JamaL9722060
in reply to: Jeff_M
Thanks you Jeff for the answer,
  1. I selected them all
  1. All what I got is just the boundary (yallow)! not contour lines!
  1. Which surface style should I apply?
What might be the issue then?
Jamal Numan
Message 10 of 11
neilyj666
See attached - you need to set the interval and Display options as well as ensuring you start off with a decent template.
By the way, have you considered a C3D training course or purchasing a book (Mastering Civil 3D 2013 is a good one) and working through the tutorial exercises??
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 11 of 11
JamaL9722060
in reply to: neilyj666
Many thanks neilyj for the help,
I got an introductory course but sounds not to be sufficient! Sure, I’ll be looking at the book you have recommended and other tutorials. As you know, never happen that a single training can cover all topics.
I love the way you answered my questions! Screenshots! Much better than words!
If your time permits, may you please have a look on the thread below. This thread is still unsolved.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Acquiring-the-x-y-z-points-of-an-alignment/m-p/379483...
best
Jamal
Jamal Numan
Rail Community
