Civil 3D Forum
Civil 3d and 7970m GPU problems
2 REPLIES 2
420 Views, 2 Replies
I have started trying out Civil 3d 2012.
 When in 3d mode and rendering there is a lot of lag and my file has started to crash often.
It is a relatively small job with about 400 drawing objects and 4 surfaces.
My computer is a Metabox laptop p150em.
Specs:
i7 2.4 Ghz with intel 4000HD on chip
16gb ram
7970m GPU
256 Gb smamsung 830 SSD
Here is the 3D performance log:
Performance Tuner Results Log
Version: 19.0.1.00
Date of Last Tune: 14/11/2012
Version: 19.0.1.00
Machine Configuration
Processor Speed  : 2.4 GHz
RAM              : 16274 MB
3D Device
Name             : Intel(R) HD Graphics 4000
Manufacturer     : Intel(R)
Chip set         : HD Graphics 4000
Memory           : 1766 MB
Driver           : 8.17.0010.1119
Your machine contains a 3D Device that is not certified.
As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website.
You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button.
Current application driver:    acaddm10.hdi
Current Effect Status:
Enhanced 3D Performance:   Available and on
Smooth display:            Available and off
Gooch shader:              Available and using hardware
Per-pixel lighting:        Available and on
Full-shadow display:       Available and on
Texture compression:       Available and off
Advanced material effects: Available and on
Available application drivers and effect support:
Software driver
Effect support:
  Enhanced 3D Performance:   Not applicable
  Smooth display:            Not applicable
  Gooch shader:              Software emulation only
  Per-pixel lighting:        Not applicable
  Full-shadow display:       Not applicable
  Texture compression:       Not applicable
  Advanced material effects: Not applicable
Autodesk driver:  Not Certified
Effect support:
As you can see its running off on chip graphics and not dedicated card.
Ive tryed fiddling wth drivers to force it to use 7970m by disabling HD drivers but it still cant find 7970m, I assume this is because 7970m uses enduro and is normally off unless it senses 3d work. I have set CAD as a high performance program in catalyst also.
I have also updated drivers but that causes more issues.
Is there any way to force Autocad to pick it up?
Also it appears that tune is dated awhile ago, is there a way to get it to re-run?
Thanks very much
2 REPLIES 2
antoniovinci
I would try to force running Autocad without enabled HW acceleration:
  1. edit the properties of the Civil icon on the desktop (or wherever you have it)
  2. add /nohardware at the end of the running string
In other words, you should have something like this:
"C:\Program Files\AutoCAD\acad.exe" /nohardware
Thanks tryed that, seems to run maybe a little quicker then the HD4000 with hardware excel turned off.
Its still sluggish though, would really love to get my 7970m cranking.
Thanks again
Rail Community
