Civil 3D Forum
Civil 3d TIN Comparison
7 REPLIES 7
Message 1 of 8
ajmagnotta
852 Views, 7 Replies
I need to determine a limit of rock cut for a land development project.  I have created surfaces for my Existing Grade and Top of Rock.  Is there any way to determine the limit of rock cut within 25 ft of the existing ground, the volume of rock cut, and show the limit of rock cut on my plan view?
I could drop the Existing Grade elevations by 25 feet, but then how would I create a searate Surface from the intersection of the lowered Existing Grade surface and the Top of Rock Surface?
7 REPLIES 7
Message 2 of 8
Joe-Bouza
in reply to: ajmagnotta
Create a volume surface of eg-25 -vs- rock. the zero contout will be the limit
Joe Bouza
Message 3 of 8
Jay_B
Generally speaking, Create a copy of your EG surface Copy Surface using Raise/Lower Surface apply a negative value of -25'.  Tin Volume Surfaces could be created for each of the 2 comparisons.
As long as one of your Surface Tin Boundaries matches the limits you want to show in plan you can extract that boundary as a polyline boundary using "extract objects from surface" command.
This is just one of several ways to get your 2 volumes for
EG_Top of rock
Top of rock_Bottom of rock
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 4 of 8
BrianHailey
in reply to: Jay_B
I disagree. I think it's a much better work flow if you create a new surface and paste the EG surface into it. This way, if the EG surface changes (What? Your EG surface has never changed? Your surveyors have the talent and forsight of God Himself!) the lowered 25' surface will change as well (if it's set to rebuild automatically or after you manually rebuild it). If you copy it, you'll have to change both surfaces.
Copying a surface works, I personally think this is a better workflow.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 5 of 8
tcorey
in reply to: BrianHailey
Very good advice.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 6 of 8
ajmagnotta
I created the volume surface based off of the comparison of the EG (minus 25') and my Top of Rock, but I can't get the boundary of my limit of rock excavation within 25 ft of existing grade.  The volume surface gives me the boundary of the Base Surface, where I need the boundary of the intersecting triangles.  Is there a way to identify the intersection of the 2 TIN Surfaces?
Thanks.
Message 7 of 8
wfberry
If you have turned on the contours, your "0" contour elevation is where they go from cut to fill. (or vise versa)
Bill
Message 8 of 8
fcernst
Ribbon
Analyze tab Ground Data panel Minimum Distance Between Surface
Command Line:
MinimumDistBetweenSurfaces
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Rail Community
