I'm trying to install the 64 Bit AutoCAD Raster Design Object Enabler and I get the Error 1406 that states "Could not write value DESCRIPTION to Key\C:programFiles\AutoCAD 2009\acdb17.dll\Application\AeciIb i also have 0e for civil3d 2011 and it works fine.
please help
Solved by SethHall. Go to Solution.
Hi tisha1-
Judging from the path you posted, you are trying to install the Raster Object Enabler for the 2009 version. Since the 2009 version was still a 32-bit application, you will need to apply the 32-bit Object Enabler. Please give this a try and let me know if this helps.
