Is there a way we can support a duel feature code ?
In the field the surveyor would enter into his file “ EWD[*TB[“ . ------This code indicates the beginning of the “Edge of Woods” and “Top of Bank” .
Each shot after that would be along the edge of woods and top of bank . “EWD*TB” -- This code indicates shots taken along the “Edge of Woods” and “Top of Bank”
The surveyor would end this feature with “ EWD]*TB]“ ---------------This code indicates the ending of the “Edge of Woods” and “Top of Bank”
Thanks for your help!
Solved by jmayo-EE. Go to Solution.
Solved by Cadguru42. Go to Solution.
Solved by rl_jackson. Go to Solution.
There are some good examples of this in the help search
Survey Linework
Rick Jackson
Survey CAD Technician VI
@mermerCAD wrote:Is there a way we can support a duel feature code ?
You could use "EWD ST TB ST" as the first shot, then the middle shots would be "EWD TB" then finish the two figures with "EWD END TB END". That's how we would do it.
