AutoCAD Civil 3D General
Valued Contributor
Message 1 of 18 (1,686 Views)
Civil 3D Service Pack 2.1 HEADS UP!!!!
1686 Views, 17 Replies
08-31-2012 08:16 AM
Had a fatal error and sent the report to Autodesk which I don't usually do because I've never heard a response.....anyways the report comes back that I need service pack 2.1.
So I download and install the service pack, well now certain profiles which include pipe networks are skewed as if the alignment has moved thousands of feet, the grid is stretched off to the side even though I did nothing to the profile stationing, or the alignment stationing, just went in to change a profile label.
I asked others in the office to open the same drawing I was working in and they do not see the profile doing this stretch.
I turned the computer settings back a few days to allow for un-install of the service pack, civil 3D didn't like that either and won't open so had to do a total un-install and re-install.
Now when I open the drawing the profile is fine..........
will send a back charge to Autodesk for beta testing the service pack
New Member
Message 2 of 18 (1,679 Views)
Re: Civil 3D Service Pack 2.1 HEADS UP!!!!
08-31-2012 08:43 AM in reply to: rrl642
Hi - I had fatal issue with the service pack as well. All of my hydrographs for swm disappeared upon install. I have contacted Autodesk and they said they are working on it. Wasted a half of day or more of my time doing a install, trouble shoot then unistall and reinstall. It is ridculous. This was a few months ago and I have heard nothing since.
neilyj
Message 3 of 18 (1,659 Views)
08-31-2012 09:18 AM in reply to: fa_michaelena
Presume you mean Hotfix 2??
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/C3D-2013-Hotfix-2-released/td-p/3599766
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
LisaPohlmeyer
Message 4 of 18 (1,645 Views)
08-31-2012 10:02 AM in reply to: rrl642
I had issues with this as well after I installed the Hotfix and rebooted.  I had to repair the install, not reinstall, thank goodness.
Lisa Pohlmeyer
C3D 2012 SP4, holding off on C3D 2014
Please use "Accept as Solution" if this solved your issue.
Employee
hgohel
Message 5 of 18 (1,638 Views)
08-31-2012 10:24 AM in reply to: rrl642
It would be very helpful if everyone in this thread could confirm if they are writing about C3D 2012 and Update 2.1 and not about any other C3D release/update/hotfix?
To the OP: Would you be able to provide us a data set we can use to reproduce the profile/pipe networks problem you mentioned with C3D 2012 Update 2.1?
Himanshu Gohel
Autodesk, Inc
LisaPohlmeyer
Message 6 of 18 (1,627 Views)
08-31-2012 10:53 AM in reply to: rrl642
Yes, sorry, C3D 2012 SP 2.1.  I had issues right after the install & reboot.  The app failed to launch.  A repair fixed it.
I also had an issue with C3D 2013 Hotfix 2 doing the same thing.  A repair fixed that as well.
I have both installed on my workstaton, no other versions.
Lisa Pohlmeyer
sboon
Message 7 of 18 (1,591 Views)
08-31-2012 12:13 PM in reply to: LisaPohlmeyer
I have an active case with Subscription Support because of a similar issue, except that mine is related to corridor feature lines that display differently after SP 2.1 is installed.
I posted in this thread about seeing the problem in 2013 first, but it has now appeared in 2012 after installation of SP2.1.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/2013-bug-corridor-feature-lines/td-p/3417687
The two screenshots show the same drawing as it appears upon opening - no redraw, regen, corridor rebuild or anthing else.  These are from the same computer.  The only difference is that the second view is after installing the SP.  Notice the feature lines that skip across from one corridor section to another one on the alignment.
Member
Message 8 of 18 (1,499 Views)
09-04-2012 09:09 AM in reply to: rrl642
We have also had major errors since installing this Pack including fatal errors, locking up, changed colors of alignments, etc. It is very frustrating and repairing the Pack has not worked.  So here we sit with our hands up, hmm... reinstall Autocad or wait and see if they come out with a fix... either way we just lost a lot of time... Thanks for keeping us proficient! :catmad:
Spoiler
Distinguished Contributor
Message 9 of 18 (1,337 Views)
09-18-2012 08:48 AM in reply to: rrl642
I'm getting ready to test SP2.1 and was wondering if everyone is still having the issues pointed out in this thread?
Anything been resolved?
-Bruce
sboon
Message 10 of 18 (1,328 Views)
09-18-2012 09:11 AM in reply to: bruce.jordan
Nope.  I finally uninstalled and reinstalled Civil3d without it yesterday.  Huge improvement in performance and my problem went away.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
