Civil 3D Forum
Civil 3D Questions
39 REPLIES 39
Message 1 of 40
3362 Views, 39 Replies
Civil 3D Questions
Hi guys, can I ask civil 3D technical questions on this Discussion groups?
39 REPLIES 39
Message 21 of 40
If you do not want to deal with a corridor and since you have a profile, you can always create a feature line from your alignment; indicate you want to use the profile for the elevations and turn off the dynamic link to the alignment.  Then use the feature line stepped offset command to create your edge of pavement, curb lines, etc.
Message 22 of 40
jmayo-EE
One other way to skin this cat, which may also help engrtech with non perpindicular curb lines.
Create a simple corridor for the pavement surface. Forget trying to model the curb with the corridor. Create a feature line for the bottom of curb, assigning elev's from the cor srf. Use the stepped offset to form the top of curb. Intersections do not need to be modeled if simple feature lines can form the intersection transitions well.
In the attached, lower right plan viewport, one intersection is detailed. The white feature lines get elev's from the cor surface, the dashed red feature lines handle the intersection transitions. If there are no intermediate elevation points or PI's on the red dashed feature lines, the intersection will be dynamic to edits in the white feature lines.
John Mayo
Message 23 of 40
in reply to: AllenJessup
Ya, there is an existing surface (P1).
I redo it again (P2), and it looks like there is a part which is not fully covered.
The message (M) pops up.
Message 24 of 40
The way I do is:
Corridor > create assembly… > see pictures.
Did i miss something?
Message 25 of 40
When I create the intersection in civil 3D, the intersection has to which type? Assume the lines in the pictures are alignments.
I used type 3 to do intersection; I got no respond from it.
Must I use type 1 & 2 to do intersection?
Message 26 of 40
in reply to: Jeff_M
Hi Jeff_M,
How can have a volume report in combination between platform level and road level?
For example:
I have Existing Ground surface, Propose ground surface (Platform Level), Road Finish Level.
Will it be possible for me to have the cut and fill volume report in combination between the data above?
Message 27 of 40
Jeff_M
Not quite sure I know what you need. But you can paste the Finish Grade and Corridor surfaces together then get your cut-fill volumes between the combined surface and the existing ground.
Does that answer the question?
Message 28 of 40
in reply to: Jeff_M
yup, i think so.
could you show me how to do?
Message 29 of 40
Jeff_M
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/empty_concept_455-905.htm
Message 30 of 40
in reply to: Jeff_M
Thanks for your information
Message 31 of 40
in reply to: Jeff_M
yesss, i managed to do it. haha.... thank you so much.Smiley Very Happy
Message 32 of 40
Jeff_M
Glad to hear it and happy to help!
Message 33 of 40
Does anyone know how to create slope using civil 3D?
Take a look at the picture; I want to make a slope after the building, which is from the cyan line. The location of the slope will be at the clouded area. I show a very simple example section on how slope looks like (see P1).
Is it possible to make it?
Message 34 of 40
hi friends
at first im from iran and my english ist good excuesme.
in civil 3d when i want to open or save a file the open or save window does not open and i must write my file name just in comment line and its hard for me.how i can set it for opening this window or this problem setting, please?
Message 35 of 40
neilyj666
You need to start a new thread but in the meantime set FILEDIA=1
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 36 of 40
in reply to: neilyj666
that was true.thank you
i asked this question in iran they sayed that you can install the civil again . you are really an engineer
Message 37 of 40
please off topic
Is it possible to manually import or using import command to import station,elevation and description only without northing and easting
Tags (1)
Message 38 of 40
zawgyi1173
in reply to: DarrenP
Hello Sirs,
Can I ask one question about civil 3d drawing export to AutoCAD drawing?
My civil 3D drawing has more than 50000points, surface and contours.
When I export it, it take too long time more than an hour,... in fact I can't wait and I haven't finished yet  and thought it was too big file size. Kindly teach me how to export that big drawing?
Message 39 of 40
neilyj666
in reply to: zawgyi1173
You are more likely to get a reply if you start a new thread
Message 40 of 40
tcorey
Not to muddy the waters here, but you asked how to get elevations along offset alignments, without using a Corridor. I agree with the other posters, and would use a corridor.
But
You can gather those ETW elevations without a corridor by using the Create Offset Alignment function. Use the Create Offset Profiles tab . Once you have the offset profile, you can add Points or labels to obtain elevations. You might find this method easier than creating a corridor, and less-taxing on your drawing size.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
