Published date: 2006-09-26 to: Autodesk® Land Desktop 2007 |
You installed Land Desktop 2007 on a computer that had or used to have Map®
3D 2006, Civil 3D® 2006, or Land Desktop 2006 installed. When you tried to use
Map functions in Land Desktop 2007 or Land Enabled Map 2007, you received
the following error message:
C:\Program Files\Autodesk Land Desktop 2007\AcMapWorkspace.arx cannot
find a procedure that it needs.
This issue occurs because the file search paths are pointing to the 2006
files for Map® functionality. You need to remove these references from your
Land Desktop 2007 AutoCAD® profiles using the following methods:
Land Desktop
Land Enabled Map
You should repeat these procedures for all of the custom AutoCAD
profiles you have created in Land Desktop 2007 or Land Enabled Map
2007.
We experienced the same problem here trying to select an alignment from LLD. We are running LDDC 2008 (32bit) in Windows 7 Pro (64bit).
The Error was:
"C:\Program Files (x86)\AutoCAD Civil 3D Land Desktop Companion 2008\aeccapp.arx
cannot find a dll or other file that it needs.
; error: ARXLOAD failed"
Launch LDD
Open OPTIONS - FILES - SUPPORT FILES SEARCH PATH. There should be a path listed as:
C:\Program Files\Common Files\Autodesk Shared\AxUi
Everything in Windows 7 32bit is installed under C:\Program Files (i86)\
Change the above directory of
to
C:\Program Files (i86)\Common Files\Autodesk Shared\AxUi
Everythig seems to work now. You may need to reassociate the project.
This maybe a flaw in the 32BIT installation process.
Hope this helps others,
