Civil 3D Forum
Civil 3D Headache....again.
7 REPLIES 7
Message 1 of 8
ACADuser
773 Views, 7 Replies
My cross sections (generated in MS) are not showing FG surfaces.  I have tried plotting single sections, multiple sections, etc. and can't get the FG surface to show.  Same problem when the min/max elevation range In the create section vew dialogue is set to values that include the FG surfaces.  Attached is a screen grab showing what I am getting.
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
7 REPLIES 7
Message 2 of 8
Joe-Bouza
in reply to: ACADuser
Not sure I understand you question but do the sample lines include FG?
Joe Bouza
Message 3 of 8
ACADuser
in reply to: Joe-Bouza
Yes, I have sampled several sources (see attached).
Odd thing is the FG surface shows up in the corridor section editor.
ACADuser
Message 4 of 8
ACADuser
Ok, after my previous post I went back to the drawing and the "Section Sources" dialog was still open.  Instead of clicking cancel I clicked on the "Apply" buttom.  What do you know - the darn FG lines appear in the sections.  FYI these surfaces had already been added as a sample source.
Is there something that would cause a "disconnect" between the section views and sampled sources ?
ACADuser
Message 5 of 8
Something to check.....your fg surface style.  See the attached pic.
Message 6 of 8
Joe-Bouza
Nice graphics, Bryan - Is that the latest release of Snagit? Smiley Very Happy
Joe Bouza
Message 7 of 8
BrianHailey
That setting is for if you want to see your surface in the corridor section editor. As far as I know, it does not have anything to do with sections created via sample lines. (Could be wrong, it's happened before. And as I don't have C3D on this computer to test it, I probably am.)
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 8 of 8
Joe- besides always providing help.....always one to bring a smile to one's face! Smiley Wink
Brian, no, I think you are correct, now that I think more about it.  There is something I am remembering back from C3d 2008 that I ran into this and it ended up being a setting of some sort similar to that.  It had to do with a surface, or corridor display setting on the actual part itself (surface or corridor), so that when you turned it on, your data would then show up in your sections.  I know the darn thing is in there somewhere, I just can't remember where.
Of course, this may not be the issue at all, but at least it can be ruled out once I find it.  I'll keep digging- I remember it was kind of burried within (as with everything C3d).
Rail Community
