Hi there,
I'm trying to recreate an existing alignment using Civil 3d 2012, however I can't get the right spiral.
The sequence is tangent + spiral+ curve. They are all fixed and I have the points where the spiral starts and ends.
Thanks.
Solved by Alfred.NESWADBA. Go to Solution.
All fixed might result in curves with none tangential break points.
What are the values you have and maybe a drawing-upload for us to see what you got/what you tried ... might help
- alfred -
>> indeed the spirals I get are not tangent so I wonder if it
>> can be done in a different way.
No, if the current specifications are that hard/that exact with start-point, end-point, radius/K/... values then I guess the specs are wrong.
If you have the chance for using some tolerances then you might use other construction types like floating curves/spirals to come as close as possible to the specs.
- alfred -
