I am trying to set up a corridor with multiple materials with multiple pavement sections. For example, I have concrete and asphalt surface pavement, about 4 different kinds of base material and 2 different subbase materials to use. It doesn't seem like you can get quantities divided up like that. It seems like you can only get the 'base' material counted up with the quantities and you can only assign one material to it. Is the answer to create multiple corridors for each pavement type that has their own Code Set to assign to each corridor? This seems like the only way it will work.
Mike
Solved by sboon. Go to Solution.
Are nine layers of Material enough?
There's a subassembly in the Lanes category that accomodates nine layers.
The GenericPavementStructure and ShapeTrapezoidal subs can be attached to each other to build a "stack" of shapes with user controllable point, link, and shape codes.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
It's an alternate solution. The OP is free to examine the help files for both subassemblies and choose whichever suits their needs.
Steve
I'm thinking the OP is trying to compute materials for different regions along the corridor. For example a length of the road may have an asphalt wearing course with unique materials for that type of surface in the pavement structure, then another length of the road will be concrete with a different set of materials in the structure, and so on. In the end we need quantities for each type of material used.
Sorry I wasn't clear. Some pavement sections have 3 layers or 4 layers, but I have a bunch of different materials that have been chosen to go in different places. So one subassembly might have econocrete as a base material and another might have crushed rock or whatever. So my question is how do you assign different materials to the same code for two different subassemblies in the same assembly or corridor.
OP = "Original Post" or "Original Poster"
The only way to apply different Materials to a single shape code would be to use multiple Quantity Takeoff Criteria sets. Each one would have to be applied to a separate sample line group, so you would have SLG-1 for the first station range then SLG-2 for the next, etc.
For what you're trying to do here I would suggest that you want an assembly that can handle all possible materials, and change the layer thicknesses to zero for the regions where you don't want to have a particular quantity. The multi layer lane sub that Fred suggested has three Base layers so you could assign econocrete to Base1 and crushed rock to Base2.
Steve
