Everytime I try to open up a drawing in civil 3d it crashes and sends out an error report. I just installed this onto my computer which already has autocad suite 2010. Is there going to be any issues with that? I can't seem to place the problem and it get's really hard to work when Civil 3D crashes everytime. Thanks for the help guys.
If the Civil 3D objects are causing a problem, you could try the following
Close Civil as AutoCAD and reopen C3D and Insert the block - but please keep in mind, if you do a "copy and paste" with DEMANDLOAD = 0 from a Drawing to another Drawing, this will not work with Civil Objects, because you are copying a "Proxy" Element in a new Drawing, and if you open that Drawing again in Civil 3D, this is still a Proxy Object!
Also by using this method you may not get all the Civil Objects from the original drawing
This sounds like a "crashing as soon as the program loads" issue. I have had this issue numerous times. Autodesk has said something about the pop up command center or something.
Check these two posts out, one of them is mine originally.
and
There are a couple of fixes, (both of which are not guaranteed to work) Try 1, see if it works, Try 2, see if it works, if all else fails Try 3
1 is directly from Autodesk about resetting some variables that control the command center or something, that annoying little popup that comes in the top right hand corner of your screen. 2 is to delete some autocad files and initiate a secondary installer to rebuild the folders and files it needs. (backup any custom toolbars, linetypes, profiles, ect)
1) Check your registry and ensure these variables are set correctly
[HKEY_LOCAL_MACHINE\Software\Autodesk\MC3]
"MC3Enabled"=dword:1
The next entry to verify is the following:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8000:409\WebServices\CommunicationCenter]
"LastUpdateTimeLoWord"=dword:00000000
"LastUpdateTimeHiWord"=dword:00000000
2) To reset the user settings
To reset the AutoCAD® Civil 3D® 2010 user settings for a particular user, follow these steps:
a. Log on to the computer as that user.
b. On the Start menu (Windows), click Run.
c. In the Run dialog box, enter regedit.
d. In the Registry Editor, browse to the following key and delete it:
e. Close the Registry Editor.
f. Using Windows Explorer, browse to and delete the following user's application folders:
For Windows XP
C:\Documents and Settings\<user name>\Application Data\Autodesk\C3D 2010
C:\Documents and Settings\<user name>\Local Settings\Application Data\Autodesk\C3D 2010
g. Start AutoCAD Civil 3D. This will initiate the secondary installer, re-creating the deleted files and folders.
3) Clean install of Civil 3D
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240697&id=13288030&siteID=123112
Hope this helps!
another couple of quick items to try would be
1) purge out your temporary directory (use %temp% for the address in windows explorer and delete all files there)
2) delete the "default" profile from the icon on your desktop (everything in the "target" past the /p switch).
Does this crash occur with any/every drawing? Create a new drawing, draw a line, save and reopen. Does that also crash?
If you sent in crash reports (CERs), can you send me your email address which I can use to find your reports for further information? himanshu.gohel@autodesk.com
If you haven't yet installed Update 1 for Civil 3D 2011, please do that as well.
Thanks.
