Civil 3D Forum
Civil 3D 2014 crashes with open dialog form or save dialog form.
3 REPLIES 3
joantopo
630 Views, 3 Replies
Every time that I open a new drawing and select the path, open file dialog appears empty
and If I  click "ok" button, then appears the following message:
I´m using Civil 3D 2014+hotfix1.
Are there any hotfix to solve this?
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
3 REPLIES 3
Karsten.Saenger
in reply to: joantopo
This is not a known program behavior in Civil 3D 2014.
I am assuming that it is more to a faulty installation. Check the vaiable FILEDIA - it should be set to "1".
Have you tried to reset the user profiles in Civil 3D, a guide how to do it can be found here:
http://usa.autodesk.com/getdoc/id=TS21789329
Karsten Saenger
Jay_B
in reply to: Karsten.Saenger
Tested the steps you've shown using 2014 HF1 here and everything works as expected.
One thing I noticed in your file path that's different from mine (in U.S.) is your path shows an \esp\ folder where
mine shows \enu\ but this may be a regional thing?
Path here:
C:\ProgramData\Autodesk\C3D 2014\enu\Data\Corridor Design Standards\Metric
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
joantopo
in reply to: Jay_B
Yes.
Filedia=1
esp= Spain, I´m using country kit Spain but it isn´t the trouble.
Maybe that it could be memory RAM, but I have 32GB. I have increased virtual memory and I have checked phisical memory with software "MemTest 86+ 5.01 release" and there aren´t any errors.
it happens sometimes, not always.
Rail Community
