hi all , in civil 3D SP2 is new bag , imported Subassemblys from SAC dos not working , when you try take it from pallet you getting thess massage: [Something wrong with current subassembly: Failed to create a 'Settings' from the text 'Assembly references and imported namespaces serialized as XML namespaces'.] (Source: Subassembly.Daylight_Cut_Fill_DitchWithBerms)
i uninstal SP2 and now works well , so plzz chek 🙂 thx
Solved by klugb. Go to Solution.
Everything is working here with SP2. I imported several Subassemblies and an Assembly without problem. All of them came from SAC.
Was yours created in the current version of SAC? All of mine were created with 2012-SAC.
Do you want to post the PKT ( have to rename it to .zip) and I can try importing yours?
