Civil 3D Forum
Civil 3D 2014 Bug in Surface Rebuild
33 REPLIES 33
Message 1 of 34
coastalgeology
5938 Views, 33 Replies
Autodesk AutoCAD Civil 3D 2014 contains a bug involving rebuilds on surfaces displayed in customized colour schemes, colour books and even the hard-copied standard colour schemes. Surface rebuilds work OK if the surface is displayed as triangles or contours but it does not work if the surface consists of Levels/ Elevations, unlike in previous versions of Civil 3D.
CIVIL 3D 2013
For a terrain surface constructed from a Point File, it is possible in Civil 3D 2013 to use the “range interval” option to provide colour banding of surface elevations over and above those 6-10 colours available in the “red, green, hydro” etc. colour schemes. By manually clicking on the “colour scheme” property in the “Surface Properties- Analysis” dialogue box, the colour can be changed to any colour available in Index Colour, True Colour, or in Colour Books, up to a maximum of 200 colour bands.
If the Points File used to construct the terrain surface later requires editing, such as to remove data spikes, and the Rebuild function is used under “Prospector/Surface/ right click on Rebuild”, the surface displayed as colour banded Elevations/ Levels changes correctly to conform to the rebuilt surface.
CIVIL 3D 2014
The above procedure does not work with 2014.
(a) Index Colour, True Colour, or in Colour Books. If you have manually selected banding from these colour options, the Rebuild transforms the colours to those in the range of whatever “red, green, hydro” etc colour scheme is defined in the Settings box for the surface style.
(b) “Red, green, hydro” etc. colour schemes. If you start off with one of these schemes, a Rebuild transforms the Elevation/ Levels surface to a single colour.
After a Rebuild, it is possible to go through the whole exercise of manually re-entering the required colours. However, I work in coastal engineering dealing with large datasets generated by multi-beam echo-sounding for seabed terrains and land topography generated from LIDAR and it is now common practice to display these terrain surfaces in a “brown-yellow-green-blue-purple” colour scheme, such schemes having been generated as Colour Books using Autodesk ACDEditor.
Having to manually re-enter from the Colour Book after a rebuild is a laborious and time-consuming task. This will also be a major problem for those whose work involves using any of the proprietary Colour Books supplied with the package, such as the Pantone ones.
Consequently, having just upgraded to 2014 in the past week and found this bug with my drawings, it is evident that a lot of my work requires continued use of 2013.
33 REPLIES 33
Message 21 of 34
mathewkol
in reply to: ishkav
You're simply changing the colours.  What happens is when you actually make an edit to the surface (add a single elevation points somewhere) and your customized analysis will be gone.
Assuming this is actually "as-designed" now, this is definitely not what we want.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 22 of 34
ishkav
in reply to: mathewkol
The fact is that as mentioned by the Autodesk Support this is as designed behavior introduced in 2014. Of course if I add a point the surface will rebuild and the analysis is gone and I knew about this "bug" since I reported it as well.
I was just answering to the post 19 on this forum. 🙂
Ishka
CAD Manager
Tom Groll Engineering
Email: ishka@tg-eng.com
Blog: http://www.civildigest.com, Twitter: C3Dish
Windows 7 x64, IDS 2014, 2013 & C3D 2012
Intel i7 930 @ 2.8Ghz, 12GB RAM, Nvidia GeForce 9600GT
Message 23 of 34
neilyj666
Apparently someone did as it actioned after a change request...Smiley Frustrated
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 24 of 34
coastalgeology
in reply to: neilyj666
Hi Neilyj
What is strange is that I have just had a reply to my SR via my reseller giving a different reason.
Civil 3D 2014 surface analysis works at the moment "as designed".
There has been changes made since C3D 2013 to correct what used to be "an issue", now, the analysis get reset when you rebuild the surface, this is an expected behavior.
That being said, we are aware that customers do not like it very much and that at least, they want to be able to store their color scheme and be able to reuse them.
We are actually debating about that "why, how, etc..."
Your customer description of the issue come in just at the perfect time 🙂
I am sharing that (and more) to fill in the customer need in a futur release.
A change request has been reopen and I will add this SR to it.
But for the time being, I am afraid there is not so much options, except may be one...
Install the UK&IE country kit, in UK&Irelands Reports, there is an "additional tools" section with tools to manage (import, export surface analysis)... please give it a try.
I hope this helps.
Please let me know if this answer your question or if I can assist further.
Thanks for your cooperation and understanding.
Best regards,
It doesn't look as if Autodesk is going to do anything about this problem sometime soon. As a couple of blog sites in the US have suggested that with the pushing of Infrastructure Design Suite by Autodesk, possibly standalone Civil 3D is going to go the same way as Land Desktop.
Message 25 of 34
neilyj666
in reply to: coastalgeology
As it is "as designed" there is no bug, therefore very low priority to get it back to pre 2014 state, I'd suggest. Perhaps this is the reason for backwards compatibility with 2013?
Message 26 of 34
dsimeone
Hi Folks - We're actively researching this issue and will update you one we have a confirmed plan. We apologize for any inconvenience and will do our best to turn a solution around as quickly as possible.
Dave Simeone
Senior Product Manager - AutoCAD Civil 3D
Dave.Simeone
Product Line Manager, Autodesk Infrastructure Products
Message 27 of 34
neilyj666
in reply to: dsimeone
Thanks for the (possibly?) positive feedback...:)
Message 28 of 34
Buzz12345
Here in Christchurch, New Zealand we're still doing a lot of accurate floor level surveys to determine damage from not so recent earthquakes.  We use a couple of surface analyses to show building managers and engineers what's going on. We never moved to C3D2013 because of the surface transperancy issues.  Some of our datasets are across several buildings with up to 8 dtms per building (depending on construction). If I'm reading the impact of this bug correctly then we wont be able to use C3D 2014, because re-setting the analysis every time is just not affordable.
Michael
AEC Collection - Civil3D 2023 & Infraworks 2023
www.foxsurvey.co.nz
Message 29 of 34
neilyj666
that would indeed appear to be the case; gotta love Autodesk for changing something that worked perfectly well...
Message 30 of 34
autoMick
The response I got to my support request also noted that "Judging from the development’s note on this, it seemed to be fixed in SP1. However, the specific release date is unknown". So I take this to mean that it's already fixed, we just have to wait for it.
Civil3d user in Australia since 2012.
Message 31 of 34
neilyj666
in reply to: autoMick
Hope it'll be a hotfix rather than a service pack; although a hotfix does imply that a bug has been fixed - which this obviously wasn't..Smiley Wink
Message 32 of 34
Query.
Why has someone has listed message 13  as a "solution"? It's not a solution, simply a response from Autodesk.
According to message 26 (from Autodesk), the problem is still being investigated. No sign of a Hotfix yet and I expect the first SP will be in 2014.
Six weeks after receiving C3D2014, still having to use C3D2013 for my work. Not looking good.
coastalgeology
Message 33 of 34
dsimeone
Note that we're actively working on a solution to this issue. I can't provide detailed schedule info publicly, but it's short term.
To confirm, the behavior we're targeting will revert back to how it's always worked in the past. When the surface updates, the elevation ranges that were previously set in the surface properties/analysis -> Range Details will remain (but updated to reflect the new surface definition).
Please contact me directly if you're interested in testing.
Dave Simeone
dave.simeone@autodesk.com
Dave.Simeone
Message 34 of 34
autoMick
Might I suggest that the appropriate behaviour would be to have a preference setting to either: 'retain surface analysis after rebuild' (as the default) or not. Obviously someone requested it to be changed, so why not keep them happy at the same time?
I'm happy to test and comment. PM sent.
Dave, in response to my service request on this issue, I was told that it would be addressed in SP1. Why not in the first hotfix? Can you confirm the timing for the fix release please?
As to why this thread has a solution, I thought only the OP could do that?
Cheers
- Mick
Rail Community
