I am currently using Civil 3D 2013, and when I do a qsave, my drawing gives me the following error dialogue box.
"Drawing File is Write Protected" - I am the only on in the files, so now my file is currently Read Only - then I am able to re-open the same file as the same time I have the currently read only version open.
I am getting this currently after or during Plan Production, creating sheets, and I do a qsave.
I am using Civil 3D 2013 Hotfix 1
Windows 7
64 bit system
12GB Ram
Quad Core Xeon 3.2
Server is using Microsoft Server 2008
Solved by machadt. Go to Solution.
Are you files save on the local drive or on a network location?
If they are save on a network location, could you please try to see what happen when you save on the local drive?
Here is an old post with a similar situation:
