As far as I know, right now, users of Civil 3D 2013 should have SP1 and Hot Fix 3 installed.
How can this be checked?
With Civil 3D 2012 you could use REGEDIT to view to list of service packs at this entry:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Autodesk\AutoCAD\R18.0\ACAD-8000:409\Service Packs
Thx.
Kevin.
Solved by Jeff_M. Go to Solution.
I get this:
Does that mean I'm missing SP.1 or you're missing Hot Fix 3, or both?
Mark Green
Working on Civil 3D in Canada
to install hot fix 3 you had to have sp1 installed already
In order to install AutoCAD Civil 3D 2013 Hotfix 3 you must have already applied AutoCAD Civil 3D 2013 Service Pack 1.
DarrenP
yes he is
DarrenP
