Civil 3D Forum
Civil 3D 2013 Servicepack 2
14 REPLIES 14
Message 1 of 15
4517 Views, 14 Replies
After installing service pack 2 Civil 3D 2013 my imported subassemblies doesn´t work anymore.
Tried to import them again but when I try to use them in an assembly i get a warning in the vista and they
won´t work
See attached png.
14 REPLIES 14
Message 2 of 15
fcernst
I'm experiencing the same. This is not acceptable.
Please submit a support request and I will do the same.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 3 of 15
mmosby
i'm also seeing the same exact error with Civil 3d 2013 SP2 and also with Civil 3d 2014 hot fix 1, will be submitting a support request also.
Message 4 of 15
genepaulacepeter
same error after installing hotfix 1 for 2014 and SP2 for 2013.
welcome to the club
Message 5 of 15
in reply to: fcernst
Just installed service pack 2.  How do I submit a support request?
Message 6 of 15
fcernst
Right here, see below:
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 7 of 15
mmosby
The Civil 3D 2013 SP2 and Civil 3D 2014 Hot Fix1 require that you install .NET 4.5...it apperas that the Subbassembly composer DLLs were upgraded to .NET 4.5 in these service packs/ hot fixes.
The .NET 4.5 is not installed when installing Civil 3D 2013 or 2014 (base, not suites) versions. .NET 4.5  does get installed in the Civil 3D 2014 Infrastructure Design Suite Ultimate Install (it did on mine when i told the installer to go out and get the updates automatically in a fresh install on another PC). Here is the link to download and install the .NET 4.5 Framework:
http://www.microsoft.com/en-us/download/details.aspx?id=30653
This fixed my issue in both 2013 and 2014 on my HP Elitebook 8560W running Win 7 64bit.
Thanks!
Mark
Message 8 of 15
fcernst
I went through this with support and it didn't help.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 9 of 15
in reply to: mmosby
A thousnads thanks, this fixed the problem
Message 10 of 15
fcernst
in reply to: mmosby
I always had 4.5 installed and was still getting the .NET errors.
Now after a large automatic Windows Update this morning I am not getting the .NET errors, but I am getting "Object Reference" errors.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 11 of 15
ceethreedee.com
in reply to: mmosby
Yep hero... worked for me.. Man i was panicking for a bit there when i saw my model update!!!
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
Message 12 of 15
in reply to: mmosby
I was wondering if any new detials had come up on this, we had a dwg. with corridors and assembles all done in Civil 3D 2012 and then we switched over to 2014 suite and now when we try to attach a sub assemble (curb, lane etc.) on the last prompt to accept it disappears and will not attach.
errors : AM Roadway chooper Macro file not found at original path specified in subassembly.  Updated macro file location to path defined by AECCCONTENT_DIR environment variable.  (Source: C:\ProgramData\Autodesk\C3D 2014\enu\C3DStockSubassemblies.dll!Subassembly.LaneSuperelevationAOR and this happens for all sub assmeblies
any thoughts on how to fix this, all help would be apprecited
Message 13 of 15
ceethreedee.com
Sounds like you have a different problem to the OP.
Suggest you post separately.
Kapanther
Infraworks 2021.1,
ceethreedee.com
Message 14 of 15
in reply to: ceethreedee.com
It´s 2 files, ADTMtlStockTools.atc and C3DStockTools.atc that you have to copy from
C:\Windows\System32\config\systemprofile\AppData\Roaming\Autodesk\C3D 2013\enu\Support\RegisteredTools
to
C:\Users\[username]\Appdata\RoamingAutodesk\C3D 2013\enu\Support\RegisteredTools
Something goes wrong when your profile is done, thoose files have to be copied by hand.
Message 15 of 15
qui_pth
in reply to: mmosby
Thank you so much. I repair Net frame work 4.6.2 and it doesn't appear this error. Thanks again.
Rail Community
