AutoCAD Civil 3D General
Active Member
tore.lindell
Message 1 of 14 (1,947 Views)
Civil 3D 2013 Servicepack 2
1947 Views, 13 Replies
08-07-2013 06:47 AM
After installing service pack 2 Civil 3D 2013 my imported subassemblies doesn´t work anymore.
Tried to import them again but when I try to use them in an assembly i get a warning in the vista and they
won´t work
See attached png.
Valued Mentor
fcernst
Message 2 of 14 (1,898 Views)
Re: Civil 3D 2013 Servicepack 2
08-07-2013 10:27 AM in reply to: tore.lindell
I'm experiencing the same. This is not acceptable.
Please submit a support request and I will do the same.
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
New Member
mmosby
Message 3 of 14 (1,846 Views)
08-07-2013 08:55 PM in reply to: tore.lindell
i'm also seeing the same exact error with Civil 3d 2013 SP2 and also with Civil 3d 2014 hot fix 1, will be submitting a support request also.
Member
genepaulacepeter
Message 4 of 14 (1,806 Views)
08-08-2013 05:34 PM in reply to: tore.lindell
same error after installing hotfix 1 for 2014 and SP2 for 2013.
welcome to the club
Valued Contributor
Topher5000
Message 5 of 14 (1,751 Views)
08-12-2013 12:52 PM in reply to: fcernst
Just installed service pack 2.  How do I submit a support request?
Valued Mentor
fcernst
Message 6 of 14 (1,743 Views)
08-12-2013 01:12 PM in reply to: tore.lindell
Right here, see below:
Fred Ernst, PE
C3D 2015
Ernst Engineering
New Member
mmosby
Message 7 of 14 (1,671 Views)
08-14-2013 04:08 PM in reply to: tore.lindell
The Civil 3D 2013 SP2 and Civil 3D 2014 Hot Fix1 require that you install .NET 4.5...it apperas that the Subbassembly composer DLLs were upgraded to .NET 4.5 in these service packs/ hot fixes.
The .NET 4.5 is not installed when installing Civil 3D 2013 or 2014 (base, not suites) versions. .NET 4.5  does get installed in the Civil 3D 2014 Infrastructure Design Suite Ultimate Install (it did on mine when i told the installer to go out and get the updates automatically in a fresh install on another PC). Here is the link to download and install the .NET 4.5 Framework:
http://www.microsoft.com/en-us/download/details.aspx?id=30653
This fixed my issue in both 2013 and 2014 on my HP Elitebook 8560W running Win 7 64bit.
Thanks!
Mark
Valued Mentor
fcernst
Message 8 of 14 (1,661 Views)
08-14-2013 04:49 PM in reply to: tore.lindell
I went through this with support and it didn't help.
Fred Ernst, PE
C3D 2015
Ernst Engineering
Active Member
tore.lindell
Message 9 of 14 (1,637 Views)
08-14-2013 10:56 PM in reply to: mmosby
A thousnads thanks, this fixed the problem
Valued Mentor
fcernst
Message 10 of 14 (1,559 Views)
08-15-2013 08:12 AM in reply to: mmosby
I always had 4.5 installed and was still getting the .NET errors.
Now after a large automatic Windows Update this morning I am not getting the .NET errors, but I am getting "Object Reference" errors.
Fred Ernst, PE
C3D 2015
Ernst Engineering
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
