Civil 3D Forum
Civil 3D 2013 Profile View Minor grid DOT displays wierd
4 REPLIES 4
DaveM
498 Views, 4 Replies
All
If you can see it in the image below, I am showing my minor grids with a dot linetype. I have a total of 6 profiles all of which appear to have the dots double up in random areas, they also print like this.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
ATI FirePro V5700(FireGL)
Win 7 Home Professional
Please use Kudos Where Deserved
4 REPLIES 4
Jay_B
in reply to: DaveM
Hi Dave,
We have a similar grid, are you by chance using 30 scale Imperial?
Recently we moved to 2014 from 2012. While our 30 scale dot linetype has always been a bit fickle when used in Civil 3d Profile Views, something has changed within C3d profile views compunding the issue you're describing.
What I ended up doing here to solve the issue was to have the linetype be slightly less than 1/6 =.16666667
that we had in our previous definition.
Going with .166666 is working here now.
We also have 20 & 50 scale Dot definitions but only the 30 causes trouble due to uneven result when dividing 50/30=1.6666667 to achieve 50' grid intervals etc.
Give the following linetype definition a try.
*DOT-30SC,30 Scale dot minor grid
A,0,-.166666
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
DaveM
in reply to: Jay_B
It is 30 Scale, Impressive sir.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
DaveM
in reply to: DaveM
Unfortunately the linetype did not help my situation, but I certainly appreciate the advice.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Jay_B
in reply to: DaveM
OK Try this.
Profile View Properties>Stations Tab>User Specified Range> Set values to even +00 or +50's
And for the ending station enter .004999 or rounded to just under 0.01 & see if that helps?
Ie: End: value  X+00.004999 or X+50.004999
C3D 2018.1
C3D 2016 SP4
Rail Community
