Civil 3D Forum
Civil 3D 2013 Point Marker Rotate Grip
5 REPLIES 5
1599 Views, 5 Replies
In previous versions of Civil 3D there was a grip on the point marker that allowed me to rotate the block used as a point marker, where did this grip go in 2013? How can I rotate an individual point marker without having to create a separate point style?
5 REPLIES 5
sboon
The marker is still there, but it's now combined with the point movement grip.  Select the point and hover over the square grip - you should get a flyout menu with options for move or rotate.
Steve
Expert Elite Alumnus
in reply to: sboon
When I hover the selected point the flyout menu does not appear. What setting am I missing?
Dan Seymour
Feist Engineering, Inc.
in reply to: sboon
Ain't happening. Selected point, hovered over grip for ten seconds , neither one has flyout.
Jeff_M
Make sure the Sysvar GRIPMULTIFUNCTIONAL is set to 3
Jeff_M, also a frequent Swamper
in reply to: Jeff_M
That did the trick Thank You
Rail Community
