I am having some issues with surface profiles on a dreffed alignment no updating dynamically.
Currently it requires me to set them to static, then back to dynamic and they update.
I am well aware of the issue of dreffed surface profiles staying static. I am using the work around of dreffing in the surface and sampling in the drawing using the dreffed alignment.
Any ideas? Anyone else run into this issue?
Kapanther
Its not the best solution because it will sync everything in the drawing every time a new open occurs...but will at least show you the correct information when you finally can draw. add the lisp to your C:\Program Files\Autodesk\AutoCAD 2017\Express --> paste-->Acaddoc.lsp..see link for attachment
