Distinguished Contributor
bkanthergolder
Message 1 of 2 (690 Views)
Civil 3D 2013 - Dynamic Surface Profiles acting as Static Profiles!
690 Views, 1 Replies
11-14-2012 10:47 PM
I am having some issues with surface profiles on a dreffed alignment no updating dynamically.
Currently it requires me to set them to static, then back to dynamic and they update.
I am well aware of the issue of dreffed surface profiles staying static. I am using the work around of dreffing in the surface and sampling in the drawing using the dreffed alignment.
Any ideas? Anyone else run into this issue?
Kapanther
Civil 3D 2014 (SP2)
Win 7 Pro x64 -DELL Precision Workstation T3500
Intel Xeon 3.3GHz (w3680) -24Gb Ram
NVIDIA Quadro 2000 (1GB)
ceethreedee.com
mathewk
Message 2 of 2 (662 Views)
Re: Civil 3D 2013 - Dynamic Surface Profiles acting as Static Profiles!
11-15-2012 07:55 AM in reply to: bkanthergolder
No solution but I've seen the problem. In my experience this can be from 2 things:
1. Corruption in the dwg (can't be fixed with recover)
2. DWGs upgraded from older releases (2012 for example).
I like to make surface profiles in the same DWG as the alignment so I never have this problem.
And to contradict my earlier statements, I've tried 2012 files organized the way you do without a problem, so that's not always it.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
