AutoCAD Civil 3D General
Active Contributor
Jon0001
Message 1 of 8 (781 Views)
Accepted Solution
Civil 3D 2013 Crashing on Export to CAD when pipes in profile view
781 Views, 7 Replies
01-10-2013 03:45 PM
So I have been getting a fatal error "INTERNAL ERROR: !dbobji.cpp@8743: eNotOpenForWrite" when I try to export to 2010 CAD.
I have worked out that it happens when pipes are displayed in the profile view.
ANyone have this problem or know of a fix?
*Expert Elite*
tcorey
Message 2 of 8 (774 Views)
Re: Civil 3D 2013 Crashing on Export to CAD when pipes in profile view
01-10-2013 04:42 PM in reply to: Jon0001
Did try a Recover?
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Active Contributor
Jon0001
Message 3 of 8 (761 Views)
01-11-2013 07:50 AM in reply to: tcorey
Yes we have tried a recover and audit and removed all xrefs
*Expert Elite*
troma
Message 4 of 8 (756 Views)
01-11-2013 10:35 AM in reply to: Jon0001
Check that none of the layers associated with pipes in profile view are locked/frozen.
Test: try exporting to ACAD 2013 first.  Then open that up and export again to 2010.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Contributor
Jon0001
Message 5 of 8 (732 Views)
01-14-2013 07:19 AM in reply to: troma
We ended up redoing the drawings and all is working fine now.
Member
engngr_ats
Message 6 of 8 (448 Views)
06-20-2013 05:46 AM in reply to: Jon0001
Keep getting the internal error.
Jon0001, redoing the drawings? What did you do exactly?
Active Contributor
Jon0001
Message 7 of 8 (442 Views)
06-20-2013 07:31 AM in reply to: Jon0001
We ended up purging the Civil 3d of all excess settings and styles and it seemed to work.
Member
engngr_ats
Message 8 of 8 (370 Views)
08-06-2013 10:52 PM in reply to: Jon0001
Decided it would be the same or easier way: save c3d .dwg with proxy images, then open .dwg in plain autocad [, explode proxies and finally remove proxies if it's nessesary].
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
