AutoCAD Civil 3D General
Active Member
aslove
Message 1 of 28 (4,389 Views)
Civil 3D 2012 text
4389 Views, 27 Replies
05-06-2011 06:11 AM
Anyone having problem with text text when editing.  It seems to hold it position after you edit and try to rotate or move the text?
wfberry
Message 2 of 28 (4,386 Views)
Re: Civil 3D 2012 text
05-06-2011 06:16 AM in reply to: aslove
Yes:
Here are a couple of options.
1.  Convert to MTEXT
2.  Run Audit with "Y" (sinc came up with this one.)
Bill
Product Support
AlmasSuljevic
Message 3 of 28 (4,375 Views)
05-06-2011 06:57 AM in reply to: aslove
Here is another one. Run AUDIT (you may not see any errors) and then keep using ED command for editing of text.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Member
mtecacad
Message 4 of 28 (4,315 Views)
05-09-2011 03:38 PM in reply to: AlmasSuljevic
Is this a bug that may be fixed soon, is causing major problems. very unproductive.
Active Member
stupidnguyen
Message 5 of 28 (4,239 Views)
05-24-2011 05:35 PM in reply to: mtecacad
I think like you!
Member
BYNUMFANYO8656
Message 6 of 28 (4,202 Views)
05-25-2011 09:51 AM in reply to: stupidnguyen
We are having this same problem. But have noticed MTEXT does not behave like this. Hopefully there will be a patch soon for this. I am getting tired of running the AUDIT command 100 tmes a day!
Active Member
aslove
Message 7 of 28 (4,199 Views)
05-25-2011 09:54 AM in reply to: aslove
I am getting sick of running Audit.  Hopefully there will be a patch out soon.
gary.lovegrove
Message 8 of 28 (4,175 Views)
05-25-2011 01:22 PM in reply to: aslove
Try setting the DTEXTED sys variable to 1
Gary
Active Member
mbm98
Message 9 of 28 (3,810 Views)
07-08-2011 08:53 AM in reply to: aslove
The city engineering team that I work for is also having the same text problem. As suggested, we tried the dtexted = 1 command and it gave us a dialog box for text entry. Unfortunately it would not retain the changes.
When we open the properties window and try to change the text we get a dialog box with the following message: "Object was open for read".
The only work around  to break out of the open for read mode appears to be Audit.
This is getting extremely frustrating and  really slows productivity. Please Autodesk give us a hot fix!
Thanks!
mbennum
Message 10 of 28 (3,701 Views)
07-15-2011 02:01 PM in reply to: aslove
I'm having the same problem, and can reproduce it on two separate computers (one workstation, one laptop).
It appears if you copy a piece of DTEXT, then text edit the original piece of text, it will get "stuck". You can't edit it again, and if you MOVE or ROTATE it dissappears until a regen. Audit, or close/reopen fixes it temporarily.
I guess switching to Mtext will fix it, but I don't like Mtext for everything.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
