I have checked my data folder and I cannot find the file Surface-7.dwg used in a surfaces tutorial. It's a multi-view block. I checked my entire hard drive and it is not there. Can the files be downloaded? I can't seem to find where I can do this.
As a matter of fact, the location where the tutuorials say to look, Windows 7: C:\ProgramData\Autodesk\ AutoCAD Civil 3D2012\enu\Data\, does not exist on this Windows 7 Home Premium computer I am using.
Solved by Jeff_M. Go to Solution.
The ProgramData folder is a hidden system folder that will not dispaly unless you configure Explorer to show them. However, this is where the tutorial drawings are located in a standard install, including Surface-7.dwg:
C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\Help\Civil Tutorials\Drawings
