There are a few commands that are not working in Civil 3D 2012. For example:
"AECCSHOWINQUIRY" for Inquiry tool, "AECCTOOLBOX" . FInally when I click on the Toolbox Icon, I get a fatal error. Anyone expericing same issues?
I just found my issue. I imported my ARG profile from 2011 and that was the problem . Why Autodesk does not make compatible these files so we don't have to change our settings every release? Kind of frustrating.
Same thing happened with my Custom CUI file I had. I tried to import it and I got nothing by problems. It happened to 2 other users. For those that run into this. Reset your profiles and do a repair.
Yes, Is pita upgrading versions when trying to migrate custom settings, especially if autodesk change the command name.
The documentation recommends using the transfer tab in the CUI Editor.
