AutoCAD Civil 3D General
Message 11 of 16 (94 Views)
Re: Civil 3D 2011
03-09-2012 04:21 PM in reply to: Sindarin
Maybe they HAVE found a way. Our tech emailed me today and said that he can't authorize an install of 2011. We are on subscription, so it should be 2012, but the user didn't want to upgrade. Hmmm....
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
C3D 2014 (SP1)
Win 7 Pro, 64-bit
Message 12 of 16 (92 Views)
Re: Civil 3D 2011
03-09-2012 04:23 PM in reply to: klugb
And they think that approach works in the "Real World"...?
Again, what are they thinking?
Sinc
Message 13 of 16 (91 Views)
Re: Civil 3D 2011
03-09-2012 04:27 PM in reply to: Sinc
To be more precise, we have multiple clients.  Some of them have stayed on older versions because they are so large that, by they time they upgrade all offices, they are already past-due for the next year's upgrade.
That's why so many want to skip every other-year.  And forcing small companies to work in newer versions, while large companies can't afford to upgrade all offices in the limited time-frame...  Well it creates nothing but massive confusion.
And that's not even getting into all the problems with upgrading from one year of C3D to the next, since we've now reached the point where even forward-compatiblity doesn't work.  (C3D 2011 drawings have problems in C3D 2012, for example. C3D 2010 to C3D 2011 or C3D 2010 to C3D 2012 are even worse.  Forget about earlier versions.  If you want to open C3D 2009 or earlier in C3D 2012, all I can say is "good luck".)
Sinc
Jeff_M
Message 14 of 16 (79 Views)
Re: Civil 3D 2011
03-09-2012 05:26 PM in reply to: Sinc
Sinc wrote:
I have been told by an Autodesk reseller that, if you are on subscription, it is illegal for you to use ANYTHING but the latest release, after 90 days of its release.  So if you are on subscription, you are violating your subscription agreement if you've been using anything but C3D 2012 since last July.
Not sure where that reseller got their information, Sinc, but as far as I can find, it is just plain wrong. This is the first definition from the Subscription site regarding the use of previous versions:
"Subscription customers are entitled to use certain Previous Versions of Autodesk products concurrently with the most current release if they meet certain conditions."
The certain conditions are more thorughly defined therein, but essentially, as long as you had a valid license for that previous version, and it within 3 releases of the current version, you meet the conditions.
Message 15 of 16 (78 Views)
Re: Civil 3D 2011
03-09-2012 05:41 PM in reply to: Sindarin
Jeff's answer is correct. The OP has not specified subscription yet. If you're on sub, you should be able to download from the subscription centre. If you don't have the credentials to log in, your Autodesk contract administrator will have them.
If you're not on sub then I'm afraid there is no download option of which I'm aware. It's my understanding that if you upgraded to 2012 and you're NOT on sub you're mandated to use 2012.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Message 16 of 16 (64 Views)
Re: Civil 3D 2011
03-11-2012 10:51 AM in reply to: Jeff_M
I wanted to attempt a add a point of clarification regarding subscription and licensing. I believe the 3 months requirement (like Matt said) applies to products that were taken off subscription and network licenses. So for network licenses you have 3 months to upgrade your license servers to the new licenses.
So for example if your current network licenses are for 2012 (with 2011, 2010, 2009 included as previous version support) you have up to 3 months after 2013 is released to upgrade the licenses to 2013 (with 2012, 2011, 2010 included as previous version support). Also, for any standalone licenses, you will likely be required to uninstall any 2009 products that previously fell under the previous version support.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
