AutoCAD Civil 3D General
Message 41 of 49 (1,591 Views)
Re: Civil 3D 2011 runs slow and likes to "not respond"
02-25-2011 09:28 AM in reply to: oceanside
Sinc,
Importing a raster image in Civil3d 2009 32 bit vs 2011 64 bit is a good comparison.  We have a 90 meg aerial photo and the time to insert the file is about 7 seconds in 2009 32 bit. (I made new Civil3d jobs using two different Civil3d versions)
In 2011 64 bit, it takes about three mintues to load the image.  To run the command "imageframe" and choose 1 or 0, it takes about 45 seconds.  It shows as not responding, but if you wait it out, it will come back.
(The computer is Windows 7 64 bit, I7 3.0 ghz 12 gig Ram, Raid 5)
Valued Mentor
granite07
Message 42 of 49 (1,254 Views)
05-24-2011 12:02 PM in reply to: civildja
same here with 2011 and 2012 C3D
documented here in another thread
http://forums.autodesk.com/t5/AutoCAD-2012/Memory-or-Video-Card-to-revitalize-old-computer/m-p/30346...
and opened a new thread specific to the 3D orbit in 2D wireframe
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/2D-amp-3D-wireframe-orbit-performance-quirks/m-p/3030...
Open-hardware workstation
AMD Deneb C3 x4 3.6 GHz
ASUS M4A87TD (non-EVO) AMD 870|SB850
16 GB DDR3 RAM 4x4 PC12800/1600MHz
OCZ REVO Drive 1RVDX0240
Liquid cooled
Server 2008R2
C3D 2012 F.51.0.0
FirePro 3D V7800 2GB RAM Driver v8.773.1.1 Server2008 (and several other cards)
Forest Peterson, granite@stanford.edu; build-sheet
Member
Message 43 of 49 (741 Views)
04-10-2012 05:04 AM in reply to: tfboles
I have researched this issue on here and I found that the SAVEFIDELITY set to "0" makes all the difference in the world in Civil3d 2011, the Saves and the random blue circles went away for us
*Expert Elite*
Message 44 of 49 (723 Views)
04-10-2012 07:33 AM in reply to: jeffbreisch5030
"Random blue circles"...?
It's very surprising that changing that option would have any real effect.  I suspect something else.  What sort of hardware are you using?
That option really only controls backward-compatibility of Annotative Objects for 2007 and earlier.  Internally, it forces a version of each Annotative object to be created as a new "anonymous block" on a different internal layer.  (You only see the one layer in Layer Manager, but "behind the scenes", Autocad will create a new layer for each Annotative Scale you're using.)  So you can end up with "runaway Annotative Scales" if you turn on ANNOAUTOSCALE, but you should typically be OK otherwise.  Unless maybe if you're running on rather old hardware.
I typically leave the visual fidelity option turned on, and have never seen "random blue circles"...  Not sure what would cause that.
Sinc
Member
Message 45 of 49 (718 Views)
04-10-2012 07:39 AM in reply to: brburklund
We have made this change on 20 Computers and 2 offices and the Difference is amazing, Maybe its some kind of glitch because, You are right it makes no sence
Intel (R) Xeon CPU  33520 @2.67ghz
12gb ram
64bit windows 7
NVIDIA Quadro NVS 420
*Expert Elite*
Message 46 of 49 (681 Views)
04-10-2012 11:53 PM in reply to: jeffbreisch5030
12gb ram
64bit windows 7
Glad you're seeing a difference.  But with your hardware, I'd STRONGLY recommend you go with a 2nd Gen (aka Sandy Bridge) i5/i7 over what you have.
One of the things that makes me very suspicious is that Intel's website does not even list the 33520 as a chip.  So I'm wondering if it's a clone/knockoff.  Also, the Xeon series in general is a waste of money for C3D, since all it does is let you use multiple CPUs (a waste for a single-threaded app like C3D), or address more memory (also a waste for C3D, which has rapidly-diminishing returns for RAM above 16GB).  You get a far better bang-for-the-buck by going with one of the 2nd-Gen i5/i7 series CPUs along with a max 16GB RAM.
And the Quadro NVS series is actually NOT recommended for C3D...  Don't be fooled by the "Quadro" in there.  The "NVS" is the key.  For C3D (and AutoCAD in general), avoid any card that has "NVS" in its nomenclature, even if it also has "Quadro" thrown in there.  If that hardware is working better for you than what you had before, then that's great, but you could do a lot better.
Sinc
BHFH
Message 47 of 49 (672 Views)
04-11-2012 02:52 AM in reply to: Sinc
@sinc: Looks like its a Xeon 3520. Equals to a i7-920 LGA1366. Its still a powerful but power hungry sytem (mine sucks 250W idle, low 400W load). I also have a i7 2600k and that system is 160W load.
Member
Message 48 of 49 (666 Views)
04-11-2012 04:14 AM in reply to: brburklund
This is a Dell Precision t3500, I have no control over what we have here, there are newer computers here also and they all have the same issues, I actually read about the setting in another thread on here and there were a lot of people Commenting on how much of a difference it made, although it still makes no sence
shelmer
Message 49 of 49 (454 Views)
11-23-2012 03:27 PM in reply to: civildja
If I have large aerial imagery, I also get very lon (5min+) regens.  I have updated to the latest certified driver for my Quadro 4000 video card, and it helped somewhat - but it is not fixed.  If I disable the hardware acceleration, the regens are instant.  Is there a paticular setting within the video settings that could be disabled as opposed to entirely disabling hardware acceleration that may help my situation?  Or something else??
quick specs:
Xeon E5-1620 3.60ghz
16gb RAM
Quadro 4000 video
Win 7 64 bit
(Dell Precision T3600)
Thanks!
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
