AutoCAD Civil 3D General
Distinguished Contributor
Message 31 of 49 (2,488 Views)
Re: Civil 3D 2011 runs slow and likes to "not respond"
11-08-2010 10:25 AM in reply to: Bugpop
Just a thought...
Civil 3D writes an instance of the image to your local TEMP directory.  I have noticed serious performance issues with a cluttered temp directory.
Message 32 of 49 (2,471 Views)
11-08-2010 11:37 AM in reply to: bigblittlerent
It does this when using the Autodesk FDO for Provider for Raster, however my regens are not unreasonable when inserting raster images in this manner.
When I attach images in the reference manager or using Raster Design I am not aware of local instances saved to temporary directories.
To be sure I have created new temporary directories for Civil 3D to use but the problem persists when images are attached in the reference manager.
Message 33 of 49 (2,457 Views)
11-08-2010 12:11 PM in reply to: oceanside
I cant even get into AutoCAD.  it freezes up before the application lauches.
Message 34 of 49 (2,448 Views)
11-08-2010 12:31 PM in reply to: justin_hogan
It's probably another issue
Open up Task Manager and see if WSCOMMCNTR2 is still running.
End the task
Message 35 of 49 (2,393 Views)
11-10-2010 12:41 PM in reply to: bigblittlerent
AutoCAD wont even load long enough to load the WSCOMMCNTR2  or maybe that is the problem it doesnt load the WSCOMMCNTR2???
Just did a fresh install per Autodesk instructions and still not responding after it starts to load.  never gets to the splash screen.
neilyj
Message 36 of 49 (2,368 Views)
11-11-2010 05:51 AM in reply to: bigblittlerent
...and this is another thing that occurs all too frequently... and inevitably causes a lot of rework
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
New Member
nathan1899
Message 37 of 49 (1,867 Views)
02-25-2011 05:20 AM in reply to: tfboles
For me if I not disable but totally exit out of Norton my issues go away.  I believe Norton is stopping some of the processes in C3D.  C3D would start to "not respond" for many things that seemed unconnected but when I shut off Norton it fixed the issues.
Civil 3D 2011 SP1
Win 7 Pro x64
4Gb Ram
ATI Firepro 4800
Dell T3500
Valued Mentor
gccdaemon
Message 38 of 49 (1,855 Views)
02-25-2011 06:13 AM in reply to: nathan1899
We're using Nortons Hosted Endpoint Protection and we don't have the long hangs like you guys are discussing.
I am experiencing a problem with my graphics card locking up my OS and have to hard reboot, but that seems to happen in other graphics heavy applications IE Google earth.
As for the not responding messages, those only pop-up because you're clicking on and off the program when it's still processing and doesn't not actually mean that autocad has locked up.
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
I7 3820 (3.6ghz quad core with HT)
32gig RAM (Corsair XMS3 4x8g)
Intel x z79 mobo (BOXDX79TO 2011 socket)
Radeon HD 7850 2gb GDDR5
Active Member
Message 39 of 49 (1,846 Views)
02-25-2011 06:42 AM in reply to: bigblittlerent
It has become my routine to disable norton for 5 hours at a time.
once the problem starts you must exit acad to stop it. (and possible reboot??)
Disabling norton after the first occurance will not stop it
Message 40 of 49 (1,831 Views)
02-25-2011 07:24 AM in reply to: tfboles
Had a similar problem with AutoCAD and Inventor 2011.   Go to the control panel, add/delete programs, and click on the .NET framework.  When it asked to remove or repair simply click on repair.  This will fix it.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
