Civil 3D Forum
Civil 3D 2011 freezes randomly
28 REPLIES 28
Message 1 of 29
tremolite
1477 Views, 28 Replies
Every couple of weeks at random, my AutoCAD just freezes up and gives me the spinny wheel like it is thinking.  No other programs on my computer are affected at all by this.  Will happen every couple of minutes for a couple minutes.  It will happen why I'm not even trying to run any commands, it just freeze.
The only temp fix I can find is that if I unplug my network cable, it will stop.  Is there some auto-update it's trying to do behind the scenes and not getting through my companys firewall?
Any help or ideas would be great.
Thanks!
Nick
Tags (1)
28 REPLIES 28
Message 2 of 29
AlmasSuljevic
in reply to: tremolite
It seems that there may be some service set up to run in the background. See if it happens regulary, it may be scheduled. Use Task Manager and see if you can identify which service is running. Virus scanner is the first thing that comes to mind.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 3 of 29
tremolite
in reply to: AlmasSuljevic
It is pretty random, hasn't happened to me in almost a month and it only affects AutoCAD.
Message 4 of 29
blt
We have this happen at least once a day on every machine we have C3D 2011 on.  If you wait it will eventually unfreeze.  Sometimes it take up to 5 minutes to unfreeze.  We have tried to determine what we were doing at the time it freezes but it not the same every time.
Bryan Thorp, PLS
Civil 3D 2017 SP1
Dell OptiPlex 990 Workstation
Intel I7
16 Gig of RAM
Message 5 of 29
Sinc
Maybe try playing with the InfoCenter Settings...?
In the upper-right, click on the downward-pointing black triangle just to the right of the search text box, then select "Search Settings".  This will call up the InfoCenter Settings panel, where you can disable some of the online stuff.  For example, you can set General -> Check for new online content to "Never", turn off RSS feeds, etc.  If your problem is being caused when C3D is trying to look online for something, then hopefully one of these settings can stop it.
Sinc
Message 6 of 29
tremolite
I'll give that a shot.
Thanks!
Nick
Message 7 of 29
tremolite
Didn't help, still doing is this morning.
I'm running twin NVIDIA Quadro FX 3800 cards and got an error this morning "The NVIDIA OpenGL driver lost connection with the display driver and is unable to continue" when doing some windows updates. Anyone have problems with these?
My computer:
HP Z600
Xeon X5650 @2.67 GHz (2)
12 bg ram
Win 7 Pro 64bit
Message 8 of 29
neilyj666
Yes it's pretty poor behaviour from C3D - I have found hitting CTRL sometimes brings it back to life at once
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 9 of 29
blt
What's your version number on your video driver?  I see that we are using the same video card.
Bryan Thorp, PLS
Civil 3D 2017 SP1
Intel I7
16 Gig of RAM
Message 10 of 29
tremolite
in reply to: blt
8.17.12.6779
I just installed the AutoCAD driver off of NVIDIA's website this morning and it seems to have taken care of the problem.  I hope that is it as I have one other system in the office with the same card/issues, and another 3 systems coming for the rest of my team.
Message 11 of 29
blt
Is this the new driver or the old one?
Bryan Thorp, PLS
Civil 3D 2017 SP1
Intel I7
16 Gig of RAM
Message 12 of 29
josephbouza5497
I'm willing to bet you have SSM open, yes?
Message 13 of 29
tremolite
in reply to: blt
I'm assuming the new driver.  Was the latest on NVIDIA's site.
SSM?
Message 14 of 29
neilyj666
in reply to: blt
SSM = Sheet Set Manager
Message 15 of 29
tremolite
in reply to: neilyj666
Ah, yes.  SSM was open.
Message 16 of 29
josephbouza5497
And if you close the Sheet Set database (right click close sheet set) and x out the pallet does you performance improve?
Message 17 of 29
blt
in reply to: josephbouza5497
On my machine when  this happened I could unfreeze it by clicking on the second monitor or by hitting the ctrl key as suggested above but I did not have ssm open.  On the machine where we had to wait 5 minutes for it to unfreeze,  ssm was open.  We will close ssm and see if that helps.  Thank for the tip.
Bryan Thorp, PLS
Civil 3D 2017 SP1
Intel I7
16 Gig of RAM
Message 18 of 29
josephbouza5497
in reply to: blt
12 Gig of RAM!
You lucky dog Smiley Wink
Message 19 of 29
touzel2
Where exactly do I go to close the sheet set manager?
Message 20 of 29
Joe-Bouza
in reply to: touzel2
At the top of the sheet list; right click>> close Sheet Set. then close the palette. It is not  bad Idead to keep paletes to a minimum so you may want to close em all, and open until performance dgrades. SSM is definately a culprit
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Rail Community
