So we are running into an issue with 2008 when drawing lines by bearing and drawings curves via a radius and delta angle. They have incorporated the lines and curves menu from Land Desktop into Civil 3D 2008. However, they made a minor, but frustrating change. In Civil 3D 2008 when you go to Lines-Create Lines-Line By Bearing you are prompted for the bearing which will accept a bearing in the format DD.MMSS just like Land Desktop. However, unlike Land Desktop, when you draw a curve by delta angle and radius (like "curve from end of object") and you go to punch in your delta angle, it interprets 45.4522 as 45.4522 decimal degrees and not 45d45'22". So it takes a bit longer to draw deeds, parcel lines, etc. in 2008 than it did in Land Desktop. It doesn't give you any notice of this on the command line or in the help.
The weird thing is in Land Desktop when you would do a line by bearing it would give you this prompt:
Bearing (DD.MMSS):
It wouldn't give you that prompt for a curve, it would just give you:
Enter delta:
It should have said:
Enter delta (DD.MMSS):
Because it accepted that. Now in Civil 3D for a line by bearing it gives you:
Current direction unit: degree, Input: DD°MM'SS.SS"
>>Specify bearing:
Though it accepts DD.MMSS
If you do a curve by delta it just says:
Specify delta angle:
You have to actually punch in 45d45'22" to get it drawn properly or 45°45'22"
Am I missing something or is there a way to draw curve deltas in the format DD.MMSS? Thanks.
Josh Nelson
