As an addendum...figured I would add it here instead of the thread
mentioned below.
The thread mentioned and ACA.msi file, whereas for C3D it's the C3D.msi
file.
I have personally installed C3D 2008 along with LDT and even Raster
Design on a 64-bit OS. All is working VERY well so far, minus the Land
Companion-Enabled Map. It worked for a while (a day) on a rather busy
drawing with FDO connections and numerous AECC points, then wouldn't let
me save once I got it opened. I worked on it in LDT and C3D afterwards
with no problem at all, so I believe it has a lot to do with the LC-EM
install or coding.
Finally, I didn't get the added entries where it was mentioned that
would be found in the options paths. I guess that was just for that
vertical....
Bryant Quinney
Construction Industry Solutions (COINS)
Irving, TX
(2008) C3D w/Vault, Map 3D, LDT, RasDes
All with latest SPs
Pentium M/2.26GHz
2GB RAM
XP Pro, SP2
nVidia Quadro FX Go1400, 256MB
bquinney wrote:
> There is hope for us yet, thanks to this thread in the ACAD Arch NG.
> http://discussion.autodesk.com/thread.jspa?messageID=5552957
> In short, it outlines a method of forcing an install of C3D via hacking,
> or tweaking, the MSI and INI file(s). DO THIS AT YOUR OWN RISK.
> DISCLAIMER: IF you use this workaround, you're on your own as far as any
> level of support. Autodesk explicitly mentions that they do NOT support
> 64-bit OSes for Civil 3D 2008 (nor intend to from what I'm hearing).
> Folks, I wouldn't expect a service pack to address the need for this OS
> support when they're currently concentrating on features and stability.
> Once that's down, I would hope there would be some testing getting done
> behind closed doors.
> Good luck with your installs!
> Bryant Quinney
> Irving, TX
> All with latest SPs for priors
> Pentium M/2.26GHz
> 2GB RAM
> XP Pro, SP2
> Jon Rizzo wrote:
>> According to Autodesk Support, they do not plan to make a 64 bit compatible
>> version of Civil 3D 2008.
>> wrote in message news:5564101@discussion.autodesk.com...
>> Are there plans to make civil 2008 compatible with x64 machines?
>> Our brand new copies cannot be installed at the moment, since our machines
>> are all x64 bit.
