I've got two surfaces. One surveyed/measured before some earthworks and one after. What I want to do is display over the entire area of the surfaces on a grid (2 or 4m) the difference in elevation at each grid point..
Thanks, Dene
Assuming you have some C3D knowledge:
Create a TIN VOLUME surface with existing as base surface and proposed as comparison surface, then you can do fancy solid/transparent colours, coloured contours or spot levels over the surface.
As you askd for spot levels, you need to annotate the TIN VOLUME surface so, Annotate > Surface > Add Labels > Surface > Spot Levels on Grid. You choose grid spacing, rotation etc and it might take a few attempts to make it look like you want.
neilyj (No connection with Autodesk other than using the products in the real world)
