AutoCAD Civil 3D General
Distinguished Contributor
csevers
Message 1 of 4 (504 Views)
Accepted Solution
Changing pipe sizes
504 Views, 3 Replies
08-23-2012 02:58 PM
I'm fairly new to using the pipe network features and knew this issue was approaching.
I know how to edit the pipe part properties to change a pipe from the size indicated in my parts list to another common size for the particular material specified. However, I've run into a non-standard size that is not in the dropdown menu, how can I add another size to the list?
Basically, I need a 1.5" on the list in the attached screep cap.
Chris Severs, EI
Windows 7 x 64 bit
NVidia Quadro 2000 Dual Monitor
6.00 GB RAM
Intel Xeon W3550 @ 3.07 GHz
Civil 3D 2013 SP 2, Civil 3D 2012 SP2, Civil 3D 2011 V3, Civil 3D 2010 V3
*Expert Elite*
Joe-Bouza
Message 2 of 4 (489 Views)
Re: Changing pipe sizes
08-23-2012 08:23 PM in reply to: csevers
You need to go into part builder and add the size. Try THIS
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
csevers
Message 3 of 4 (468 Views)
08-24-2012 06:00 AM in reply to: csevers
Thanks!
Chris Severs, EI
Windows 7 x 64 bit
6.00 GB RAM
*Expert Elite*
Joe-Bouza
Message 4 of 4 (449 Views)
08-24-2012 01:39 PM in reply to: csevers
HTH
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
