I would like to change the manning coefficient for multiple existing pipes. I can't use the Panorama tool as it doesn't provide this parameter.
How could I do this?
Thank you
Solved by Matt_Haokip. Go to Solution.
You may want to either select the properties of each individual pipes and change the Manning's value OR export to Storm Sewers extension and globally edit it and import and update it to the network.
