Civil 3D Forum
Changing e-max value introduces an “exclamation mark”,
4 REPLIES 4
JamaL9722060
511 Views, 4 Replies
I wanted to select an emax of 6% but sounds that the horizontal curve is flagged by “exclamation mark” (attached). What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
4 REPLIES 4
Radius too small for that rule/that value?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Many thanks Alfred for the answer,
It sounds that the exclamation mark keeps appearing if the values other than 4% for the emax is selected.
How this issue can be solved? How to choose for example a value of 6% for the emax while avoid having exclamation mark (attached)?
Jamal Numan
sboon
in reply to: JamaL9722060
I believe that the warning is to tell you that the superelevation needs to be recalculated.  Try that and see if the warning disappears.
Steve
Expert Elite Alumnus
JamaL9722060
in reply to: sboon
Thanks sboon,
The issue here that exclamation mark is kept appearing for all values of emax other than the 4% irrespective to the radius and speed chosen.
Then how to have the emax, for example, to be 6% without having the exclamation mark to appear?
Jamal Numan
Rail Community
