Changing e-max value introduces an “exclamation mark”,
I wanted to select an emax of 6% but sounds that the horizontal curve is flagged by “exclamation mark” (attached). What might be the issue here?
Thank you
Best
Jamal
Radius too small for that rule/that value?
- alfred -
Many thanks Alfred for the answer,
It sounds that the exclamation mark keeps appearing if the values other than 4% for the emax is selected.
How this issue can be solved? How to choose for example a value of 6% for the emax while avoid having exclamation mark (attached)?
I believe that the warning is to tell you that the superelevation needs to be recalculated. Try that and see if the warning disappears.
Thanks sboon,
The issue here that exclamation mark is kept appearing for all values of emax other than the 4% irrespective to the radius and speed chosen.
Then how to have the emax, for example, to be 6% without having the exclamation mark to appear?
