Civil 3D Forum
Changing Alignment Label Sets Starting Station
14 REPLIES 14
Message 1 of 15
23241 Views, 14 Replies
Is it possible to modify a label set to a new starting station, e.g., instead of the alignment starting at 0, change it to start at 100?
14 REPLIES 14
Message 2 of 15
uncheck the box next to start station and type in whatever station is needed.
Message 3 of 15
Sorry, I didn't state the question correctly.  What I'm trying to do is change the labels on the alignment shown in picture 2 to start at a higher number than zero, but when I try unchecking the Start Station column, I just get the error as shown in picture 3.
I would like to be able to change this without recreating the alignment.
Pat
Message 4 of 15
Jeff_M
Select the alignment. Either right-click, or from the ribbon, select Alignment Properties. On the Station Control tab edit the stationing to whatever you please.
Jeff_M, also a frequent Swamper
Message 5 of 15
Or you can create a expression to achieve the result you want, under the Alignment>label styles>Station>Major Station, right click on Expression and select new…., in the Edit Expression dialog box, under the expression area, put in “{Station Value}+40000” 40000 being the start station that you want, once you have the expression create, you can apply that new expression into your major station label style. That way, you aren’t changing the geometry itself instead you just change the label.
Message 6 of 15
peterfunkautodesk
I would modify the alignment to start at the number that you want and not mess with the label set. You can start the alignment from any station value you need either when you start drawing the alignment or at any point in the project. After setting the starting station of the alignment, the labels will reflect that automatically.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Message 7 of 15
ccoles
in reply to: Jeff_M
<snip>
Oops. Peter's right. Change it at the alignment properties, not the labels menu. The alignment can start with any value you select, not just zero.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
Message 8 of 15
in reply to: ccoles
Thanks to you all.  Anyone who searches this thread, look at the attached picture to this reply to see the solution.
Pat
Message 9 of 15
in reply to: peterfunkautodesk
When I tried this, my profile, sample lines, sections and corridor were all deleted. Is there any way to avoid this?
Message 10 of 15
Changing the alignment staioning in the Alignment Properties can cause already created profile views, sample lines, and corridors associated with that alignment to behave very strangely, even vanish. You have to go into each element through the Prospector and change their relative stationing to reflect the revised alignment stationing for them to return to normalcy, and that's a lot of work. This is why changing the labels through an expression, as suggested by an earlier contributor, is a viable idea at this point. However, as others have mentioned, and to avoid some real connundrums down the line, changing the stationing via the Alignment Properties is the best long term solution. This is my recommendation as well.
For this reason, it is HIGHLY recommended to get the stationing right before you create profiles, corridors, etc.
Message 11 of 15
Is there any way to change the DEFAULT Starting Station for an alignment?
As a rule, my company starts stations at 10+00 instead of 0+00.  Not sure why, but it'd be nice to change this once and never have to deal with it again.
Thanks!
Message 12 of 15
sfreemancad
I have this same issue, I need my stationing to begin at 1+00, but in the alignment properties under the station control tab, the reference point options are not available to modify... i dont understand how everyone else can do this
Message 13 of 15
FDGJames
in reply to: sfreemancad
What version are you using?  In 2017 I get a Warning pop-up but it still lets me change the starting point.
AutoCAD Civil 3D 2018.3
Message 14 of 15
As long as you are in the source drawing for the alignment, you should be able to edit the starting station. Enter the value in the field you circled and press the "Apply" button.
Another way that you could do this is to add a station equation at the start of the alignment.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Message 15 of 15
sfreemancad
in reply to: FDGJames
2017, but i just realized that I was accessing the alignment properties
from the dxref as opposed to the alignment dwg, once I opened and tried in
the parent it worked
Rail Community
